The Edge hump and how it affects size... - Jemsite
post #1 of 6 (permalink) Old 05-19-2002, 07:45 AM Thread Starter
I've looked through the Trem section in the Guitar area of the site. I've been told to do this repeatedly, I still cant find it... what are the actual differences SIZE wise???
Is the Edge shorter in length because it has a higher profile and hasnt been 'squashed' out or is it basically the same shape and size as the lo-pro but just high profile??? As a matter of interest, which would one have MORE luck retrofitting... if it is smaller I assume it would be the edge?!
Please dont close this straight away and please excuse my ignorance if there is a topic that refers to this but I honestly cannot find it...
cheers Kevin
Kev Brigden is offline
post #2 of 6 (permalink) Old 05-19-2002, 10:00 AM
Re: The Edge hump and how it affects size...
cheers Kevin
what are you trying to retrofit it to?
As a side note, ladies always told me size doesn't matter )
Polaris20 is offline
post #3 of 6 (permalink) Old 05-19-2002, 10:30 AM
EKG
Here is what I get:
Edge base is 2.64 in [66.9 mm]
Lo-Pro base is 2.77 in [70.4 mm]
HOWEVER, the OVERALL length is longer on the EDGE due to the string lock screws. The Lo-Pro would actually take a smaller route.
For complete diagrams, see Edge and Lo-Pro, coutesy of Rich, Ibanez Rules!!
Edit: corrected links
EKG is offline
post #4 of 6 (permalink) Old 05-19-2002, 02:52 PM Thread Starter
Cheers for the info EDDIE!!! yet again you come to my aid !!!
kevin
post #5 of 6 (permalink) Old 05-20-2002, 07:52 AM
is it still the case that there are different trem-block lengths on different edges from different guitars?
I know the radius used to use a different block to the RG/Jems, and I think there was a third size too...
--c.
earthman is offline
post #6 of 6 (permalink) Old 05-20-2002, 12:31 PM
we gotta get back in time, when Edges weren't recessed yet, and when the Radius, the Saber and a few others, had just a slightly recessed cavity, not as deep as they are since early '90s...
nuno is offline
string lock
Edge blocks size 7 Stringer All Other Guitars (including Prestige) 17 01-12-2014 07:14 PM
Edge 3 tremolo bar size ryanboy2004 All Other Guitars (including Prestige) 6 01-31-2013 07:36 PM
Lo-Pro Edge saddle size(s)? Paw Tech: Setup, Repairs and Mods 1 08-14-2011 04:20 PM
edge or edge pro trem insert size 7/16 rizzobx Tech: Setup, Repairs and Mods 6 08-27-2009 09:22 AM
edge or edge pro trem insert size 7/16 rizzobx Tech: Setup, Repairs and Mods 0 08-25-2009 10:29 PM
