Edge III vs. ZR - Jemsite
post #1 of 5 (permalink) Old 11-08-2010, 05:37 PM Thread Starter
Edge III vs. ZR
I am looking at buying an Ibby sometime soon. I was wondering which was the better trem. The Edge III or ZR?
wazupwiop is offline
post #2 of 5 (permalink) Old 11-08-2010, 05:56 PM
Re: Edge III vs. ZR
None of the above. Look for something with an original Edge, Edge Pro or Edge Lo Pro.
Jack Secret is offline
post #3 of 5 (permalink) Old 11-08-2010, 08:20 PM
Re: Edge III vs. ZR
the ZR is a much better trem, especially when you remove the ZPS from the back. But it doesn't have as much range, but that's probably due to the thin S series body. This is the trem i use, and it holds tuning very well. But if not setup perfectly, it just eats through strings. (but this might be the same with all trems?). The ZR2 removes the arm socket weakness that the original ZR has. I've had to replace mine, but it's a cheap easy fix.
The Edge 3 would be a decent trem if it was made of more solid materials. The knife edges wear out on those things quick and lose tuning. But you can do a direct drop in with an Edge-pro. So you could buy the Edge 3, wear it out, then put in a very good Edge Pro in there.
Hope that helps. Toodles!
julzius is offline
post #4 of 5 (permalink) Old 11-09-2010, 07:44 AM Thread Starter
Re: Edge III vs. ZR
I think I will probably buy an Ibanez S then. All I really want the trem to do is raise half a stem, and dive a whole step or so. I was thinking about a Fender strat, but I really like Ibanez and Floyd Roses.
post #5 of 5 (permalink) Old 11-09-2010, 09:25 AM
Reviews: 11
Re: Edge III vs. ZR
Yes, the zr is superior trem by far. Some like it, some don't.. It was fine to me, especially with schaller trem arm mod.. But remember that it feels nothing like normal floyd rose.
FrostStorm is offline
edge , iii , resistance , rg bridge , zr bridge
LF: Lo-Pro Edge, Edge Pro or Edge Pro II in Madrid Spain kevlahnota Classified Ads: Guitars and Gear 2 03-24-2010 11:40 AM
FT Ibanez Edge Pro Powder Cosmo Black for Edge Pro Gold supergirl20_06 Classified Ads: Guitars and Gear 2 12-02-2009 10:05 AM
FT Ibanez Edge Powder Cosmo Black for Edge Pro Gold supergirl20_06 Classified Ads: Guitars and Gear 1 06-26-2009 04:45 PM
WTB: Ibanez edge/LP edge/edge pro saddle mounting screws Ratit Classified Ads: Guitars and Gear 0 04-18-2009 08:16 PM
Replace Edge Pro With Edge/ Lo-pro Edge Trem Vaistarr Tech: Setup, Repairs and Mods 28 04-01-2008 12:18 PM
