edge metals - Jemsite
post #1 of 17 (permalink) Old 11-12-2008, 06:46 AM Thread Starter
edge metals
what kind of metals are the ibanez edges made out of?
i scratched a tiny bit of the mirror finish off my edge zero and it's clearly made of an orangey copper looking metal. but i'm sure it can't be copper...the nut locking bolts seem to be made of the same stuff, where the string has worn through the mirror finish orange is visible.
what about edge pros and lo pros and so forth?
people always harp on about trem metal quality and how it affects the guitar's performance, but how much effect does it really have?
Homebake is offline
post #2 of 17 (permalink) Old 11-12-2008, 07:19 AM
Re: edge metals
I don't know (Rich is gonna come up with the correct answer, I suspect), but could it be brass?
Jacob K is offline
post #3 of 17 (permalink) Old 11-12-2008, 07:29 AM Thread Starter
Re: edge metals
i thought about that, but it's not goldish. definately more coppery than brassy.
Homebake is offline
post #4 of 17 (permalink) Old 11-12-2008, 07:29 AM
Re: edge metals
a lot. for example, steel made trems enhance sound incredibly, you just got to hear it to believe. it bumps up mids and mid-trebles quite like turning your amp settings 3 to 8. also, the knives won't get worn as they do in the most other (non-steel) trems, as well as the trem posts.
i guess the original Floyd Rose is the only steel-made trem around.
nuno is offline
post #5 of 17 (permalink) Old 11-12-2008, 07:32 AM Thread Starter
Re: edge metals
the edge zero doesn't use a knife edge though, right?
i'm more interested in terms of keeping tune properly and so on.
Homebake is offline
post #6 of 17 (permalink) Old 11-12-2008, 07:41 AM
Reviews: 7
Re: edge metals
I remember a thread on this for some reason. I remember the metal having a wierd name, some alloy used specifically in injection molding.
brothersnowgone is offline
post #7 of 17 (permalink) Old 11-12-2008, 08:30 AM
Re: edge metals
it does: http://www.ibanezrules.com/namm/2008/hardware.htm#EZ
if the knives and posts don't wear out (being made of steel), and if everything else is ok, then the tuning will always stay perfect.
nuno is offline
post #8 of 17 (permalink) Old 11-12-2008, 12:35 PM
Re: edge metals
I thought they were just some kind of cheaper dye cast metal?
PBGas is offline
post #9 of 17 (permalink) Old 11-12-2008, 12:58 PM
Re: edge metals
Spelter, white metal, pot metal, take your pic.
The copper is just plating.
Rich is offline
post #10 of 17 (permalink) Old 11-12-2008, 04:34 PM
Reviews: 120
Re: edge metals
Gotoh licenced Floyd Rose seems to be steel made too.
LonePhantom is offline
post #11 of 17 (permalink) Old 11-14-2008, 05:00 PM
Re: edge metals
Wouldn't Schaller's Floyd be steel, too? Everyone says it's the best around and it mentions hardened metal pivots or something like that.
Pulsar is offline
post #12 of 17 (permalink) Old 11-14-2008, 07:39 PM
Re: edge metals
oh, if it was solid copper i would melt down mine and sell it!
callen3615 is offline
post #13 of 17 (permalink) Old 11-20-2008, 02:36 AM
Re: edge metals
yea, i guess it is since FR patents went down. i did forget about it. too bad Ibanez didn't take this chance to begin making some steel parts (saddles, knives, trem block etc).
nope, the Schaller isn't steel. probably the knives are, but the rest of the trem isn't. and this makes lots of difference sound-wise.
nuno is offline
post #14 of 17 (permalink) Old 11-20-2008, 09:11 AM
Re: edge metals
I'm pretty sure the injection moulding alloy used for Edge trems is Zamak.
It's a blend of Zink Aluminium copper etc. It's the material of choice for die-cast toys. Easy to mould, decent properties, easy to finish.
A machined Aluminium trem would be stronger, by about a factor two, but also three times lighter, leading to completely different flutter characteristics. Check the 1980s Ibanez Allan Holdsworth for one.
A machined steel trem would be overkill (about as heavy as Zamak but six times stronger) very expensive, and without treatment, rust-prone.
A stamped, stainless, hardened steel trem is lighter, and very durable (orig Floyd) but doesn't look as nice.
eviltwin is offline
post #15 of 17 (permalink) Old 11-23-2008, 05:45 PM
Re: edge metals
Khaler makes a steel trem.
AxeHappy is offline
edge , metal , pro
Edge posts w/ set screw. Will they fit in an Edge III hole? Stygian Tech: Setup, Repairs and Mods 1 06-23-2008 05:57 PM
Replace Edge Pro With Edge/ Lo-pro Edge Trem Vaistarr Tech: Setup, Repairs and Mods 28 04-01-2008 12:18 PM
WTB: Edge Pro Tremolo or Trade for mint Original Edge For_The_Love_Of_Jems Classified Ads: Guitars and Gear 3 02-12-2008 01:24 AM
Edge/Lo-Pro Edge/Edge Pro Arm (x2) damo7v Classified Ads: Guitars and Gear 0 11-25-2006 02:16 PM
WANTED: Edge or Edge Lo-Pro Tremolo Whammy Bar sfx70 Classified Ads: Guitars and Gear 2 01-19-2006 01:07 PM
