Edge Pro - Jemsite
post #1 of 5 (permalink) Old 11-20-2006, 12:09 AM Thread Starter
Edge Pro
If i used an Original Floyd Rose instead of a Edge Pro, would the OFR fit? If this helps, I'll be most likely using thelegacy's JEM bodies.
LethalAe86TypeR is offline
post #2 of 5 (permalink) Old 11-20-2006, 09:51 AM
Re: Edge Pro
time and time and time again! why do u want to put an ofr in?
projectjem is offline
post #3 of 5 (permalink) Old 11-20-2006, 02:26 PM
Re: Edge Pro
If you're getting a custom body and want to use an OFR, why not just tell them you want it routed for an OFR when you order it?
technomancer is offline
post #4 of 5 (permalink) Old 11-21-2006, 11:44 PM
Re: Edge Pro
if you want a ofr let them know you want the ofr routing, if not, tell them the edge rounting...
JJ
Ironjose is offline
post #5 of 5 (permalink) Old 11-21-2006, 11:46 PM
Re: Edge Pro
and make sure he drills the right size holes for the OFR studs or itll be edge or nothing
crevis is offline
floyd rose
Edge III swap for another Edge model trem? lespaulreedsmith All Other Guitars (including Prestige) 39 12-21-2017 07:11 PM
Edge mysteries solved!!......? - Answers to some common ques Jason Stone Tech: Setup, Repairs and Mods 18 05-27-2008 09:35 AM
I just put an Edge in my RG470! DirtyBird31 Tech: Setup, Repairs and Mods 10 09-14-2007 12:22 AM
edge, lo pro and edge pro are 100% drop in fit dex Tech: Setup, Repairs and Mods 47 10-18-2005 12:29 PM
lo pro edge vs edge pro 7 cakewalkr7 Tech: Setup, Repairs and Mods 4 02-11-2005 12:23 AM
