Edge Pro arm holder loosens by itself (weird) - Jemsite
post #1 of 9 (permalink) Old 07-19-2010, 08:51 AM Thread Starter
yeah so what happens is when I put the whammy bar on and play it for a while the arm holder loosens a bit(it turns by itself)and even when I tighten it to the max(using a flathead screwdriver)it loosens again...also I should say that the holder is like 1 mm above the baseplate of the trem
thanks
deathmetallist3 is offline
post #2 of 9 (permalink) Old 07-19-2010, 09:25 AM
Re: Edge Pro arm holder loosens by itself (weird)
There should be a nut below the baseplate....Try putting a drop of loctite on that and retightening it. With it tightened up at the top and with that nut underneath, it really shouldn't move. Alternatively, you can do what I did and put an OFR arm into the guitar. It's 100x better with this setup. I have always hated that stock IBZ bar.
Here is an article on it by Stew....which was very helpful when I did mine! I ordered my bar from a place called stewmac.com
http://www.jemsite.com/forums/f21/re...s-34038-5.html
PBGas is offline
post #3 of 9 (permalink) Old 07-19-2010, 10:50 AM Thread Starter
thank you very much PBgas!I'll try it and see
BTW do you know a place where I can order that part in Europe?
post #4 of 9 (permalink) Old 07-19-2010, 01:58 PM
I know that you have a few JC's, so instead of creating another thread, is there any way that you know of to keep an Edge Zero tremolo arm absolutely tight?
Melek Taus is offline
post #5 of 9 (permalink) Old 07-20-2010, 07:25 PM
Mine haven't loosened as of yet....if you are talking about the trem arm mount. If that is the case with yours, then the same procedure would apply. You'll have to take out the trem from the body, loosen the nut below the base and above it and then put some kind of thread locker in there and retighten both nuts above and below. I've had mine for a couple of years now and I use them daily. They've stayed tight, thankfully!
However, As far as keeping the arm tight in the socket, I haven't had that issue to deal with as of yet. You tighten the collar a bit more to keep it from swinging, but you probably know that, already.
PBGas is offline
post #6 of 9 (permalink) Old 07-22-2010, 12:53 PM
I had the same problem but got it fixed by warming up those nylon washers for ~5 seconds over the open flame without removing them from the arm. It makes them expand and harden a bit which helps alot.
Sounds crazy, but it fixed mine. I read that somewhere here, can't remember the thread.
Cheers
bancika is offline
post #7 of 9 (permalink) Old 08-17-2010, 06:20 AM
i had this with my edge pro equiped universe and rg black white marble swirl, and a new lo-pro edge. using a screw driver wont do anything what you have to do, is slacken the strings. put som blue tack on to the trem posts to stop em moving if you want your set up to remain the same, as the edge pro ones dont lock like the old ones (progress eh!) right now you have done that. take the back plate off (remember slacken strings first.)
then unscrew the spring retainer bar off the back of the block, then take springs off. then while doing this take care when turning guitar back over as you trem unit is free to swing out and hit you or the guitar. and it will still be attached to strings (you can leave em on) right now you should have the trem unit in your hands and guitar on your lap. studdy the arm holder and you will notice that is is held in place by a big nut this is the problem. get a monkey wrench on it and tighten it up. and you wont have a problem again and the trem will be much more responsive as you would hope it is. i had to do this last weekend with my universe. and i smile alot more now. its fun.
robhayes is offline
post #8 of 9 (permalink) Old 08-22-2010, 12:12 AM
Is it possible to put an Edge/LoPro/EP arm into an EZ?
post #9 of 9 (permalink) Old 08-22-2010, 12:43 AM
Reviews: 98
Rich ships international, so he is the one to inquire. He has just about every Ibanez part you can think of, and is a top-notch fellow! When I need a part, he's the only one I'll deal with. In fact, I keep Rich on the same loyalty pedestal as Ibanez and DiMarzio.
AlaskaBat is offline
arm holder , edge pro
Arm holder from Edge fits ZR? Sledgeman Tech: Setup, Repairs and Mods 4 06-07-2009 03:11 PM
Edge Pro arm holder trouble ChopDuel Tech: Setup, Repairs and Mods 3 03-25-2007 06:18 AM
Tightening Edge Pro Arm Holder?? HOW?? AmazinAzian12 Tech: Setup, Repairs and Mods 10 01-11-2007 09:14 PM
Can Edge Arm Holder Fit onto Lo-TRSII lewis_ho Tech: Setup, Repairs and Mods 4 05-06-2004 10:22 PM
Trouble w/ Arm Holder Spring in Lo-Pro Edge - Help! elfstones Tech: Setup, Repairs and Mods 11 03-31-2002 02:25 PM
