Edge-Pro II to Lo-Pro Edge - Jemsite
post #1 of 13 (permalink) Old 03-23-2006, 10:50 AM Thread Starter
Quickly one.
http://www.jemsite.com/jem/trems.htm
"...you can replace one with the other with no modfications"
But..do I have to bore(or something), if I change my bridge to Lo-Pro Edge from Edge-Pro II in my rg370?
Mathias is offline
post #2 of 13 (permalink) Old 03-23-2006, 01:30 PM
Re: Edge-Pro II to Lo-Pro Edge
that quote refers only to original edge and lo-pro models.
damo7v is offline
post #3 of 13 (permalink) Old 03-23-2006, 01:54 PM
Yup, you will need to do some routing .
Regards
André
fettouhi is offline
post #4 of 13 (permalink) Old 03-25-2006, 05:21 AM Thread Starter
Thanx for your info.
Where I can find measures of lo-pro?
Mathias is offline
post #5 of 13 (permalink) Old 03-25-2006, 04:04 PM
I actually just tried this process 20 minutes ago... it ALMOST fit lol so close.. but when I went to put the TRS lopro into the edge I slot, it was way off lol
Guess ill have to just keep it as is for now, and someday buy a jt580lp or so, heard its the only thing that can replace a lo-TRS II =[
NickCormier is offline
post #6 of 13 (permalink) Old 03-25-2006, 04:39 PM
If you have a lo TRS II trem you can swap with an OFR directly.
Regards
André
fettouhi is offline
post #7 of 13 (permalink) Old 03-25-2006, 05:40 PM
Why change to JT-580LP? It´s basically the same thing with a different brand name on it. Why not try OFR?
Heka is offline
post #8 of 13 (permalink) Old 04-01-2006, 10:25 AM
lol the jackson floyd may be a copy and may be cheap but at least its not the edge pro 2. It's actually a much better bridge and if it is a direct drop in i would certainly consider droping in my rg320
ShadowSong is offline
post #9 of 13 (permalink) Old 06-23-2006, 06:47 PM
Correct me if I'm wrong, but I don't think routing is that hard. I heard the only thing you need to do is widen the trem studs [the holes into which the actual studs go in to] and cut a small amount of wood from the face of the guitar and it should just drop right in.
AKMG is offline
post #10 of 13 (permalink) Old 06-23-2006, 07:09 PM
Dee
Go for the OFR.
Dee is offline
post #11 of 13 (permalink) Old 06-23-2006, 08:52 PM
Reviews: 120
Or the Gotoh
If you are replacing a LO-TRS and want to put in an Edge I actually just used a dremmel and some hand sanding to make the route more even and it came out quite nicely.
LonePhantom is offline
post #12 of 13 (permalink) Old 06-24-2006, 02:13 AM
Originally Posted by LonePhantom
Or the Gotoh
What about if I want to replace an Edge III with an Original Edge?
AKMG is offline
post #13 of 13 (permalink) Old 06-24-2006, 03:46 AM
Reviews: 120
I guess if the posts are at the same points you could do that too.
pro edge , trem studs
Edge III swap for another Edge model trem? lespaulreedsmith All Other Guitars (including Prestige) 39 12-21-2017 06:11 PM
Edge mysteries solved!!......? - Answers to some common ques Jason Stone Tech: Setup, Repairs and Mods 18 05-27-2008 08:35 AM
I just put an Edge in my RG470! DirtyBird31 Tech: Setup, Repairs and Mods 10 09-13-2007 11:22 PM
edge, lo pro and edge pro are 100% drop in fit dex Tech: Setup, Repairs and Mods 47 10-18-2005 11:29 AM
lo pro edge vs edge pro 7 cakewalkr7 Tech: Setup, Repairs and Mods 4 02-10-2005 11:23 PM
