Edge pro ll trem arm fix. - Jemsite
post #1 of 3 (permalink) Old 06-04-2005, 09:15 AM Thread Starter
Man! I just typed out a LONG fix for this only to have it dissapear when trying to post it!!!! If anyone is interested in this fix(takes out wiggle,looseness and requires far less maintenance) let me know. I will try to detail; it again. I hate one finger typing!
rockon1 is offline
post #2 of 3 (permalink) Old 06-05-2005, 08:12 AM Thread Starter
Re: Edge pro ll trem arm fix.
Ok heres a not very detailed description of fix.-it is a bit invovled but well worth it.However you need to be comfortable disassembling your trem.In a nutshell you disassemble the trem ,remove plastic trem arm bushing.Then cut a piece of .008-010 (the thicker the better without making trem arrm too tight) automotive type feeler gauge to fit in channel where tension screws arm located. Back out the screws first,install piece of feeler gauge then reinstall bushing. Test arm for fit before reassembling trem. If OK(not too tight) reassemble trem. I did this to mine months ago and havent retightened it since! I use my trem a lot too.BTW-This is a must mod IMO. Without it the trem arm wont stay tight for long and the adjustment screws will eventually cut thru the bushing and destroy the arm!HTH Bob.
Per haps someone can move this to the correct forum-my mistake....
rockon1 is offline
post #3 of 3 (permalink) Old 04-06-2013, 01:01 PM
any pictures sir of your set up
fourth_cycle is offline
trem arm
FS: Double Edge Trem (piezo equipped trem) Guitarmattms Classified Ads: Guitars and Gear 0 01-23-2014 10:12 PM
xiphos with edge pro trem and original edge studs/anchors ibanguitar All Other Guitars (including Prestige) 2 10-15-2013 10:45 PM
How can I check whether my RG2570 body takes an Edge Pro or Edge Zero trem? JayCartay All Other Guitars (including Prestige) 6 11-18-2012 06:23 PM
How to remove ZR trem, destroy it, then install Edge trem? bdk Tech: Setup, Repairs and Mods 16 07-25-2010 01:33 PM
FT: Black Cosmo Lo-Pro Edge Trem for your Chrome Lo-Pro or Original Edge Trem parker_fly Classified Ads: Guitars and Gear 4 02-19-2005 03:18 PM
