Edge Pro quandry - Jemsite
post #1 of 8 (permalink) Old 06-29-2012, 10:32 PM Thread Starter
Edge Pro quandry
Hey all, have an interesting situation with the Edge Pro on my RG2550e. I have not had any issues getting it set up correctly and it stays in tune perfectly as long as I don't use it anywhere other than my home. I have attempted to use it in our worship band on 3 separate occasions and each time it will go out of tune (flat) to the point that I need to tighten the spring claw in order to retune it to concert pitch (I have a Fender strat that's floating and have never had any similar issues with it). When I get it back home, I have to loosen the claw and retune. I live in a fairly moderate climate and the church is only 2 miles from where I live. It's perplexing to have it stay in tune for at least 2 months at home but have it fluctuate so much over a short period of time, usually no more than 2 hours for it to go out of tune. The only variable that I can deduce is the springs. I've blocked the trem and it will stay in tune anywhere I take it so the strings or setup don't seem to be a cause. Any info, advice or comments would be greatly appreciated. Thanks
sonofiam is offline
post #2 of 8 (permalink) Old 06-29-2012, 11:00 PM
Reviews: 98
Re: Edge Pro quandry
Double check your intonation and trem angle:
It may sound strange, but maybe it's due to tuning to the band members. Maybe they're off a bit, so you have to compensate for them. Or, maybe you're not exactly in tune at home.
Sounds weird, tough.
AlaskaBat is offline
post #3 of 8 (permalink) Old 06-29-2012, 11:03 PM
Temperature. If it's cooler there it will go flat there.
Rich is offline
post #4 of 8 (permalink) Old 06-30-2012, 12:40 AM
Reviews: 98
Or....maybe the Jem doesn't like church...lol.
post #5 of 8 (permalink) Old 06-30-2012, 02:02 AM Thread Starter
Thanks for your comments.
1. It's not the set up. I used the Prestige manual as well as the website you referenced to double check it.
2. All guitar and bass players use the same tuner, a Peterson Strobostomp, which has been checked with the keyboards we use to make sure we're all in tune. I use the same tuner at home.
No comment
That was my original thought but it doesn't affect my Strat nor did it affect either of a couple PRS' I had.
I'd really like to get this figured out. I love the tone and feel of the RG but I just don't have the time between sets to tune it to the extent that it seems to need.
sonofiam is offline
post #6 of 8 (permalink) Old 06-30-2012, 04:50 AM
I think the reason why it doesn't affect those as much is because they are less sensitive trems. You have a lower range of motion for the PRS and Strat trems (i'm guessing they're both 6 screws). I've found that floyds are quite finicky when dealing with temperature changes. More parts = higher chances of something going wrong.
BlanK is offline
post #7 of 8 (permalink) Old 06-30-2012, 08:39 AM
Reviews: 13
This made me laugh haha!
RyansJem is offline
post #8 of 8 (permalink) Old 06-30-2012, 08:55 AM
This! if your using AC at one place and not at the other or not as much, it will cause big problems, I have my house temp and Humid controlled, when I go to band practice, I always have issues.
Jamm'n Jimmy is offline
edge pro , prestige , springs , trem
ARGH!!!!! in a quandry!!! 80's tribute guitar scottop1972 Pickups & wiring 14 12-26-2010 02:56 PM
LF: Lo-Pro Edge, Edge Pro or Edge Pro II in Madrid Spain kevlahnota Classified Ads: Guitars and Gear 2 03-24-2010 11:40 AM
WTB: Ibanez edge/LP edge/edge pro saddle mounting screws Ratit Classified Ads: Guitars and Gear 0 04-18-2009 08:16 PM
Replace Edge Pro With Edge/ Lo-pro Edge Trem Vaistarr Tech: Setup, Repairs and Mods 28 04-01-2008 12:18 PM
Universe quandry! Mission1979 Tech: Setup, Repairs and Mods 2 03-26-2007 02:31 PM
