Edge Pro saddle problem... - Jemsite
post #1 of 12 (permalink) Old 11-29-2007, 08:10 PM Thread Starter
Unhappy Edge Pro saddle problem...
...Basically, I don't remember seeing this before. My Edge Pro saddles are properly intonated (or were when it was set up), and the high E to A saddles are level with each other (height). The low E, however, is not, and has 'sat up', a bit, and is therefore a bit higher than the other saddles (I can post pics if necessary). I took an allen key to the saddle and lowered it to the level of the others. Retuned, and it was fine, briefly. The low E rapidly lost tuning, and it continued to do so until the saddle was at the same raised level retuned. I repeated once, and the same thing happened. Has anyone else found this? Have I got a bad saddle? Thanks
JRBain is offline
post #2 of 12 (permalink) Old 11-30-2007, 07:33 AM
Re: Edge Pro saddle problem...
Originally Posted by JRBain View Post
...and the high E to A saddles are level with each other (height)
you mean they're all the same height? that's not supposed to be like, in the EdgePro trem. saddles height must form an "arc" like following the fretboard radiusing. they even can't be all the same height as the baseplate they're sitting on is not flat, but radiused itself.
...I took an allen key to the saddle and lowered it to the level of the others.
hm!?! EdgePro saddles can't be individually set in height (except by adding shims underneath, which is not the case)! are you sure your trem is an EdgePro? post pics please.
nuno is offline
post #3 of 12 (permalink) Old 11-30-2007, 10:46 AM Thread Starter
Apologies for the bad description. Here are a couple of pics that hopefully might illustrate the problem a little more.
JRBain is offline
post #4 of 12 (permalink) Old 11-30-2007, 10:52 AM
Does the fine tuner work? --Jason
jkahrs is offline
post #5 of 12 (permalink) Old 11-30-2007, 11:36 AM Thread Starter
Never thought to check that. Just did, and no, it doesn't seem to at all. The tension hasn't slackened, but it has no effect.
JRBain is offline
post #6 of 12 (permalink) Old 11-30-2007, 11:52 AM
SeanB's Avatar
This happened to me on my Edge III. All I had to do was loosen the saddle screw and move it back a bit. It looks like it just slipped forward...
Hope that helped
Regards
-Sean
SeanB is offline
post #7 of 12 (permalink) Old 11-30-2007, 03:09 PM Thread Starter
Hope that helped
Regards
-Sean
OK. Does this not affect the intonation? Thanks
JRBain is offline
post #8 of 12 (permalink) Old 11-30-2007, 03:44 PM
Make sure the end of the saddle where the fine tuner screw touches isn't broken. There was someone on here a while back with that very problem on a ep. --Jason
jkahrs is offline
post #9 of 12 (permalink) Old 11-30-2007, 04:50 PM Thread Starter
Great - thanks; I'll look into that.
JRBain is offline
post #10 of 12 (permalink) Old 12-02-2007, 06:46 PM Thread Starter
Thinking about this, is it fixable if it is broken? Do I need to buy a new saddle? Thanks
JRBain is offline
post #11 of 12 (permalink) Old 12-02-2007, 11:02 PM
It's not a fixable problem. If it's broken, you'll need a new saddle. --Jason
jkahrs is offline
post #12 of 12 (permalink) Old 12-03-2007, 08:42 AM Thread Starter
OK - thanks dude - I bet it'll be expensive over here
JRBain is offline
fretboard radius
Loose saddle on Edge 3 Rorschach Tech: Setup, Repairs and Mods 0 01-09-2006 09:25 AM
Saddle problem on Edge Pro ThomasBJ Tech: Setup, Repairs and Mods 11 04-12-2005 02:05 PM
Lo pro edge & Double Edge in tune problem Raffel Tech: Setup, Repairs and Mods 21 05-14-2004 08:59 AM
EDGE PRO PROBLEM! PLEASE HELP! Adagio_777 Tech: Setup, Repairs and Mods 7 04-24-2004 05:25 AM
I have a screw loose! - LO Pro Edge problem. jem7vwh Ibanez JEM, UV, JS & Other Signature Models 2 03-13-2001 08:23 PM
