Edge Studs higher on one side then the other - Jemsite
post #1 of 6 (permalink) Old 02-16-2011, 10:09 PM Thread Starter
Reviews: 4
I've just acquired a 1991 squared heal RG550 and in the process of refinishing. I realized after disassembling the guitar, the Studs on the high E side is slightly higher (abour 1 mm) and not sitting straight in. Will that affect my set up next time?
faekildare is offline
post #2 of 6 (permalink) Old 02-17-2011, 12:01 AM
Re: Edge Studs higher on one side then the other
the edge studs have a locking screw that locks the stud in place. the locking screw is tiny and is IN the stud itself. you will need a smaller allen wrench to un loosen the adjusting screw that is located within the stud. so that you can lower the stud further.
Also, things to double check..
1. examine the neck and pocket joint. see if there are any debris that prevents the neck to sit correctly and level in the neck pocket.
2. probably when you reassembled the whammy system, you switched the two studs around.
3. there is probably dust and debris in the stud insert that prevents it from being lowered futher.
dgabriel713 is offline
post #3 of 6 (permalink) Old 02-17-2011, 12:11 AM
Reviews: 98
One website, all of the answers:
AlaskaBat is offline
post #4 of 6 (permalink) Old 02-17-2011, 12:15 AM Thread Starter
Reviews: 4
Sorry, my bad. I meant the stud inserts. The high e string side is higher than the other side.
post #5 of 6 (permalink) Old 02-17-2011, 12:54 AM
Reviews: 64
So set them at the same height.
What's the problem?
6fingers is offline
post #6 of 6 (permalink) Old 02-17-2011, 12:57 AM Thread Starter
Reviews: 4
I cant pull out the stud inserts. Think the previous owner set it with epoxy...
JEM7V-WH - trem not even / one side higher than the other JulianH Ibanez JEM, UV, JS & Other Signature Models 5 12-11-2009 05:43 PM
Edge studs on an Edge Pro equipped guitar? bringer of torture Tech: Setup, Repairs and Mods 2 09-18-2007 06:28 PM
Question about the edge pro bridge on higher end Ibanez elpingua All Other Guitars (including Prestige) 3 11-19-2005 09:20 AM
Angling the trem, bass side higher, causing problems? DoctorCrunch Tech: Setup, Repairs and Mods 6 01-21-2003 04:47 PM
