Edge zero bar rattle - Jemsite
post #1 of 3 (permalink) Old 11-28-2017, 03:52 PM Thread Starter
Hello
I just picked up an RG3570z in a trade.
I have owned several edge and lo-pro bridge guitars, but never an edge zero.
I saw in a video that the bar tension is controlled by the thumb nut around the bar.
I have that tight but the bar still has play and it clicks when I use it for a chord vibrato.
Are there any bushings that I can replace like on the bar for the edge/lo-pro?
Any other solutions?
Thank you in advance.
jacksguitarplanet is offline
post #2 of 3 (permalink) Old 11-28-2017, 03:56 PM
Re: Edge zero bar rattle
Yes, there is a bushing under the torque cap to eliminate rotational play. But there will always be a little lateral play in all pop in bars. A wrap of scotch tape on the bar over the detent should remove most if not all of it.
Rich is offline
post #3 of 3 (permalink) Old 12-21-2017, 10:56 AM Thread Starter
Thank you for the ifo! I will give it a try.
Replacing Edge push-in bar with screw-in collar bar? ben_ Ibanez JEM, UV, JS & Other Signature Models 2 06-15-2016 11:17 AM
WTT: Edge/Lo-Pro Edge Whammy bar for Edge III (black) GuitarAl96 Classified Ads: Guitars and Gear 0 07-25-2013 10:30 AM
Edge Pro Rattle guitarman13 Tech: Setup, Repairs and Mods 7 01-12-2009 08:13 PM
WANTED: Edge or Edge Lo-Pro Tremolo Whammy Bar sfx70 Classified Ads: Guitars and Gear 2 01-19-2006 01:07 PM
Tightening Whammy bar on Edge Tremlo - Can I tighten the bar warthog Tech: Setup, Repairs and Mods 6 05-01-2001 10:09 PM
