Edge Zero Bridge - Jemsite
post #1 of 13 (permalink) Old 10-01-2010, 05:48 AM Thread Starter
Edge Zero Bridge
Hi, my edge zero bridge doesn't stay in tune, and I think that it is because the knife edges are worn out, because when I adjusted the action on this guitar, I turned the trem post without loosening the strings. I don't want to put chapstick on the knife edge ever time I restring, and I want to solve the problem for good, so I was wondering if it was possible to fit an OFR without rerouting the guitar.
Thanks
Remy0325 is offline
post #2 of 13 (permalink) Old 10-01-2010, 06:24 AM
Re: Edge Zero Bridge
before you buy a new one, maybe you could try to sharpen the knives with a small file...could save you some $
bancika is offline
post #3 of 13 (permalink) Old 10-22-2010, 10:20 PM
The posts on the Zero are too far apart to change to other bridges. So unless you go major surgery, you are stuck with it for life.
darrenw5094 is offline
post #4 of 13 (permalink) Old 10-26-2010, 04:23 PM
Just adjusting the action a few times with the strings to pitch is not enough to cause that much wear to the knives.
I've been doing it on my RG550 for the past 20 years and have little trouble with it. The guitar does go ever so slightly sharp on a pull-up, but not even enough that the average listener notices.
If your guitar is going badly out of tune, it's most likely something other than the knives.
Check that everything is tight, make sure the strings are stretched and you don't have to Chapstick EVERY time, I've found that once every year is plenty, if even that often, and even then, I haven't put any on my 550 in several years, and it's still fine.
Even putting a real Floyd (you can't, by the way) on there isn't a 'for sure' fix to a guitar going out of tune. The Ibanez Edge bridges, even though people aren't that happy with the Edge Zero, are some of the best on the market.
Again, check everything before you simply assume you've 'ruined' your knives by adjusting the action. I've done it so many times with zero problems I can't even begin to count, so I'm guessing you didn't destroy your knives just by adjusting the action and there's something else that's causing the problem.
MicJustMic is offline
post #5 of 13 (permalink) Old 10-26-2010, 11:32 PM
Reviews: 11
yea dude, i cant give you any fix's because 1. i have an edge pro and have never touched an edge zero and 2. my edge pro has never had problems but i WILL say that the edge zero kicks the s**t out of the OFR. "original" doesnt mean the best. most of the time its the one with the most problems and the hardest to use because if its the original, then it was made before they had time to work out the kinks or even know what they are. because the OFR itself hasnt much changed since its 1st release, which is why they still call it original
D.M.RG7620 is offline
post #6 of 13 (permalink) Old 10-27-2010, 11:01 PM Thread Starter
Maybe replacing the locking nuts might help, because I found out that my locking nuts were really worn out, and the string even cut in the the locking nuts. I dont know how this happened, maybe I'm over tightening my locking nuts?
Remy0325 is offline
post #7 of 13 (permalink) Old 10-28-2010, 12:48 AM
You only need to tighten them enough to hold the string. Don't over do it.
I just tighten gently until it stops then bounce my finger off of the wrench a couple of times.
Try that, then detune the string a little using the tuning key behind the nut. If it goes flat, you didn't tighten enough.
It takes a little practice to get it just right, but NEVER over tighten them, as you've seen, you can damage to lock-blocks and even the nut itself.
post #8 of 13 (permalink) Old 10-28-2010, 02:47 PM
VCR
If you are smashing the strings with the lock nut you are going to far. Most obvious with the wound strings
VCR is offline
post #9 of 13 (permalink) Old 10-29-2010, 12:58 PM
Did you keep the ZPS bar on the trem? All three of my Edge Zero's are fantastic. They stay in tune super well. I've had no issues with them. I have my Edge Pro to compare with on my RG1527 and I like the Zero much, much better.
PBGas is offline
post #10 of 13 (permalink) Old 11-03-2010, 11:04 AM
I found a good way of doing it is to insert the long part of the allen wrench into the screw, so you're turning it using the short section. You've got less torque at your fingertips that way and its hard to overtighten. Sounds like a pretty daft tip, but i started doing it after cutting a few strings by overtightening myself.
nevla is offline
post #11 of 13 (permalink) Old 11-03-2010, 11:16 AM
Whatever works!
No such thing as a 'daft tip' if it's something useful to even one person reading.
Unless of course you tell someone to use a power-drill to tighten the hold-downs... that would be a pretty daft tip.
post #12 of 13 (permalink) Old 11-03-2010, 12:54 PM
That is a great tip! Once that pad grips the string, you really don't have to wrench it. You are just squashing the end even more. Good tip!
PBGas is offline
post #13 of 13 (permalink) Old 11-03-2010, 12:59 PM
I just realized...
After I got a set of wrenches from stewmac with ball-ends on them, I've been doing the same thing, just never really thought about it.
The ball-ends allow you to go in on an angle (like for the saddles on an Edge Pro, where the fine-tuners can get in the way) and I just got into the habit of using only the balls and since they are on the long end I didn't even realize I was using it.
See? Good tip, not 'daft'.
edge zero , edge zero issue , swapping bridges , tuning problem
LF: Ibanez Edge or Lo Pro Edge bridge in Cosmo Black supergirl20_06 Classified Ads: Guitars and Gear 0 09-19-2010 10:02 AM
JS100 bridge swap??? Edge Pro / Edge Pro II n7uqa Ibanez JEM, UV, JS & Other Signature Models 8 06-04-2009 11:35 AM
Replacing an Edge FX (fixed bridge) with an Edge Pro or OFR? twooos Tech: Setup, Repairs and Mods 13 10-28-2007 02:29 AM
Replacing an Edge FX (fixed bridge) with an Edge Pro or OFR? twooos Tech: Setup, Repairs and Mods 1 10-21-2007 07:06 PM
Edge bridge repairs - post & knife edge jd Tech: Setup, Repairs and Mods 6 12-09-2002 05:48 PM
