Edge Zero Bridge : Set-up problems - Jemsite
post #1 of 9 (permalink) Old 12-13-2015, 03:57 PM Thread Starter
Hey, I have an Ibanez RG1570Z, which the Edge Zero trem. It's been around two years with this guitar, and up until recently, it played like a dream. I prefer Standard-low action, .09-.42 string guage. Whenever I had to restring, I gave it to someone from a music store nearby (the only one in town) to do so. And if ever the action seemed to get bad and way too high, he fixed it for me by tightening the action studs at the bridge. Little did I know he was doing it wrong.
After playing for a couple of days, the action went way too low with a lot of string buzz and choking. SO I went over to the store once again and he told me it would have something to do with the truss rod. So he adjusted my neck, but the action got way too high and uncomfortable for me. So he worked with the action studs again and set it up for me.
When I came home and read about it, it turns out you have to use a smaller allen wrench and first loosen the stud locks inside the bolts prior to setting up your action. Well I guess the guitar tech from the store didn't do that and now when I tried it myself I can't do it. It's like the stud locks are stuck. The guitar is playing alright but it gets out of tune really fast now. And the action could still be lowered down (which would my more comfortable to me) but now I just don't know what to do. It turns out the guy doesn't know anything about edge trems.
It seems like he's broken the set screws (the smaller studs inside the bridge studs)
Near the lower end of the bridge (near the high E,B,G strings), the allen wrench seems to get stuck every time I check for the set screws/locking studs. On the other end, it seems to be pretty loose and I can't tighten it. From what I've read on the net, it seems like when they're tightened and the stud is locked, you can't change the action. But I somehow am able to change the action in the current situation. Could this be because they aren't locked?
Is my guitar going to be alright?
If it's not, what should I do in order to get the inner stud locks back to how they should be? And also, there's still some chokes that I'm experiencing on the 17th/18th frets, whenever I bend. Help me out anyone?
omertaxtx is offline
post #2 of 9 (permalink) Old 12-13-2015, 06:00 PM
Re: Edge Zero Bridge : Set-up problems
What year is it? The 1570z was a one year model here and I don't think the set screws were installed in them. They would be in the pouch with the tools.
Rich is offline
post #3 of 9 (permalink) Old 12-13-2015, 06:25 PM Thread Starter
Got mine in the summer of '13. And they were pre-installed.
post #4 of 9 (permalink) Old 12-13-2015, 06:31 PM
In 13 they would have been.
You obviously need a better tech.
Rich is offline
post #5 of 9 (permalink) Old 12-13-2015, 06:37 PM Thread Starter
Yes of course. It's sad out here the fact that the techs aren't familiar at all with edge trems. For a better tech, I'll have to make a visit to New Delhi. And that'd only be possible after a while. A few months I guess. Right now the guitar seems to be playing pretty good, except for the few chokes I experience when I bend on higher frets. That could be fixed by fret leveling.
What do you reckon I do?
post #6 of 9 (permalink) Old 12-13-2015, 06:41 PM
You either learn how to work on it yourself, network with other players to find somebody close that knows how to work on these guitars, they may not be a pro but probably knows why more than the store guy, or, you make the long trip.
Rich is offline
post #7 of 9 (permalink) Old 12-13-2015, 06:47 PM Thread Starter
Right.
Do you think that the guitar might have been damaged in some way because of the set screws being damaged, if that's the case?
post #8 of 9 (permalink) Old 12-13-2015, 06:49 PM
I doubt it. You don't unlock set screws with an allen wrench, you raise the action to unlock the set screws.
Rich is offline
post #9 of 9 (permalink) Old 12-18-2015, 09:22 PM
I did it myself, with some confidence from Rich, got it setup. Never goes out of tune.
As Rich said, I think it's something you should familiarize with instead of relying on someone else.
Jeesan is offline
edge zero , ibanez , prestige
WTT: my Gold Schaller FR bridge for your Black Lo Pro Edge or Edge bridge supergirl20_06 Classified Ads: Guitars and Gear 2 08-05-2011 05:57 AM
NGD + bridge problems :( Levi79 All Other Guitars (including Prestige) 7 10-17-2010 10:18 PM
First time with ZR Bridge & Problems, HELP! xmacvicar All Other Guitars (including Prestige) 12 12-03-2008 02:54 PM
RG550 and Edge problems with the Edge trem, please advice LaXu Tech: Setup, Repairs and Mods 7 08-13-2002 04:38 PM
Edge and Lo Pro Edge problems after action change - I don't Kremlin Tech: Setup, Repairs and Mods 13 07-20-2001 03:34 AM
