Edge Zero II...Any good? - Jemsite
post #1 of 21 (permalink) Old 03-01-2012, 07:46 PM Thread Starter
I've used the edge pro before with the Ibanez rg1750, I sold that guitar though.
I am looking at the Ibanez RG350MZ, And it comes with the Edge Zero II with the ZPS system. Is this tremolo half decent or is it a just a piece of garbage? I am hoping to get this guitar and get fret work/new pickups/set up done to it instead of buying an expensive guitar. And it easy to set the intonation on this guitar?
Just needs some reviews on this bridge before I order to try it out.
Thanks
d4rin is offline
post #2 of 21 (permalink) Old 03-01-2012, 08:41 PM
Re: Edge Zero II...Any good?
It is a very good trem. I have one on my RG350MYE 2011.
I feel like the RG350 2011 and newer, is like the RG550 of today.
It's a gret guitar, I play it a lot and I have 8 JEMs.
sebastian is offline
post #3 of 21 (permalink) Old 03-01-2012, 09:17 PM Thread Starter
8 Jems, Wow you're quite a collector! If you say that the Edge Zero II is good you must know what you're talking about.
Is adjusting the action/intonation easy on this guitar? Does it come with an intonation tool like on some of there other models?
d4rin is offline
post #4 of 21 (permalink) Old 03-01-2012, 09:32 PM
No tool, I never used a tool on my JEMs.
I just let most of the tension off the string and adjust the bridge, then tighten the string up again and check.
post #5 of 21 (permalink) Old 03-01-2012, 10:23 PM
Its a great trem for sure!
I have one as Sebastin does, I also have one coming on a RGXXV1.
Jamm'n Jimmy is offline
post #6 of 21 (permalink) Old 03-02-2012, 03:27 AM
it's an awesome trem. In fact, it apparently performs better than the Edge Pro, due to it's locking studs. Probably feels a bit different from the Edge, and LoPro Edge, but awesome nonetheless. It comes with the ZPS system, the thumbwheel for adjusting tension and the 2 removable springs.
If you do get it, i would suggest you take the ZPS springs out of the guitar- they make the bridge a bit too firm, and i find they have no REAL benefit.
My point is, it is a wonderful bridge. I have one in my RG370 (2011)
nikm13 is offline
post #7 of 21 (permalink) Old 03-02-2012, 07:47 PM Thread Starter
Sounds good...What's the quality of this guitar compared to a (prestige) model. I am sure prestige models have better fret work, But that can always be done, And I can also change parts. Like new pots and pickups.
Would this guitar require f-spaced pickups?
d4rin is offline
post #8 of 21 (permalink) Old 03-03-2012, 05:13 AM
It will probably need F-spaced pickups, unless you put in an X2N, or something like that(with big-arse pole pieces or the blade thingies).
The quality of the guitar is apparently a mixed bag, but my guitar is excellent. Some parts can get loose over time(trem arm holder, tone pot starts becoming shaky) but they are simple to fix and as far as i know, something that happens to pretty much every guitar over time. However, all in all, they are fantastic guitars.
nikm13 is offline
post #9 of 21 (permalink) Old 03-03-2012, 05:28 AM
I took the black ZPs springs out and just left the two lsilver ones in.
I've had nothing go wrong. My only gripe, a small one, is the jack is on a football plate.
I like the RG jacks that mount right in the wood of the body, the barrel kind, not the old Fender kind.
You need F-spaced pickups just like a JEM or any other Ibanez floating trem guitar.
See mine- before and after-
http://s878.photobucket.com/albums/a...50M-YE%202011/
post #10 of 21 (permalink) Old 03-03-2012, 12:52 PM
I second that.
The input jack is loose on my guitar. The actual jack, not the football plate thingy it's mounted on.
It is literally shaking every time i move the guitar.
Not to 'hijack' the thread or anything, but is there a way to fix that???
BTW, awesome guitar. Which pickups are those???
nikm13 is offline
post #11 of 21 (permalink) Old 03-03-2012, 01:26 PM
EVO2 (bridge)
Fast Track-1 (Middle)
EVO (Neck)
Take the plate off and tighten the nut that holds the jack to the plate.
post #12 of 21 (permalink) Old 03-03-2012, 02:20 PM
Reviews: 4
Take the plate off and tighten the nut that holds the jack to the plate. Then put blue loctite on the threads, otherwise it will go loose every week until you tighten it so much the threads bare.
Fix'd, good buddy
fwd0120 is offline
post #13 of 21 (permalink) Old 03-03-2012, 03:10 PM
I suggest using a little loctite. It'll just keep getting loose on you, otherwise. I used the red stuff which is a bit overboard, but it's been tight for the last year.
xXLinkageXx is offline
post #14 of 21 (permalink) Old 03-03-2012, 03:13 PM
best trem i used so far
pipsqueej is offline
post #15 of 21 (permalink) Old 03-03-2012, 03:35 PM Thread Starter
I used the own the Prestige 1570 with the Edge Pro, And that trem seemed very solid....
As for parts getting loose, Well they probably put cheap pots in there, Cheap input jacks, Cheap pickups. I am going to change all those anyhow and get some Dimarzio pots + a quality jack.
It's made in Indonesia so I know some of the parts are going to really suck, And the fret work will most likely need to be leveled/fret dress. And that can just be done by a tech.
d4rin is offline
Is this a good Edge trem unit? fowl2338 Tech: Setup, Repairs and Mods 2 08-22-2010 12:20 PM
Is the Edge Zero good enough? jono Polls 27 11-05-2009 11:30 AM
Need A Really Good Quality Pic Of An Edge Tremolo kam_23ca All Other Guitars (including Prestige) 27 11-03-2006 11:41 PM
Why doesn't the Lo-Pro flutter as good as the Edge? Dee Tech: Setup, Repairs and Mods 15 08-21-2006 02:03 AM
Double Edge - How good does it really sound Jay Satriani All Other Guitars (including Prestige) 11 09-11-2001 11:43 AM
