Edge Zero ii Opinions - Jemsite
post #1 of 10 (permalink) Old 03-12-2015, 07:42 AM Thread Starter
Now that the Edge Zero ii has been out for a few years I was wondering what those of you who own them think of them. I did a search and have really only found old reviews that seem to cover the tremolo in new condition. Anyone had it a couple years now and still pleased with the stability?
Sportrider24 is offline
post #2 of 10 (permalink) Old 03-12-2015, 08:34 AM
Re: Edge Zero ii Opinions
6 months only. No problems.
panix is offline
post #3 of 10 (permalink) Old 03-12-2015, 09:43 AM
I had it for over 2 years, not a problem. I didn't really use the arm, but the bridge itself is very stable.
MatiasTolkki is offline
post #4 of 10 (permalink) Old 03-12-2015, 12:48 PM Thread Starter
Thanks for the replies guys. How easy is it to float? I used to have an early 90s RG570 with an original edge and I never had any issues floating it. I could take all the strings off and restring it and that sucker would float right back to position without any adjustment hassle. I've also owned a couple of Ibbys with the edge iii and floating the trem was always a pain in the rear.
post #5 of 10 (permalink) Old 03-12-2015, 02:21 PM
Hmmmm is it a 7-string? Things are a little trickier with 7-strings. Mine floats well but it needs its streching and adusting period. It is not so one-time job and forget about it. At some point I was driven crazy, it takes more skill to master it than a dummy non-floating 6-string classic OFR. But it is ok.
Just make sure to silence the springs as well.
panix is offline
post #6 of 10 (permalink) Old 03-12-2015, 05:15 PM Thread Starter
Not a 7 string and I don't mean to make it sound like the original edge was no work. I just remember being able to change strings and never having to adjust the claw to compensate. The tremolo just seemed to always go right back into perfect floating position after strings were on and stretched.
With my RG350DX the edge iii seemed like I always had to adjust the spring tension. It took quite a while to set up in comparison to the RG570.
post #7 of 10 (permalink) Old 03-13-2015, 12:52 AM
Its 100% due to the springs sensitivity to weather changes, or just sensitivity. IMHO it has nothing to do with the trem itself. I experience your symptoms with my edge zero ii-7. The slightest change needed readhustment of claw. I think not any more. If you leave it where it is and stop bothering it, it will stop bothering you.
panix is offline
post #8 of 10 (permalink) Old 03-13-2015, 10:34 AM
A friend of mine has the edge zero 2 on his new 7 string. He said the only complaint he had was the arm holder not being the push in type like the lopro but the screw on type. Otherwise it seems ok.
moebius is offline
post #9 of 10 (permalink) Old 03-13-2015, 11:28 AM Thread Starter
Thanks to all of you for the help. Planning a new guitar purchase soon and was considering a Prestige RG655 but I don't want to spend $1200 if I don't have to. I'd be just as happy with a S670QM assuming the Edge Zero ii is good enough tremolo.
post #10 of 10 (permalink) Old 03-13-2015, 12:05 PM
^^^ it is good enough!
panix is offline
edge zero ii
Opinions on EDGE PRO II trem... Capink All Other Guitars (including Prestige) 24 02-11-2009 12:27 PM
Opinions on the edge pro II trem? Roadstar All Other Guitars (including Prestige) 8 04-29-2006 10:59 PM
Opinions wanted on Double Edge Trem (piezo) NandrewJ All Other Guitars (including Prestige) 5 08-25-2005 08:49 AM
Opinions on Universe - Need opinions on guitar Given to Fly Ibanez JEM, UV, JS & Other Signature Models 19 10-01-2001 07:26 PM
Mesa/Boogie Mark IV-any opinions? - Suggestions, opinions, e vaijem777 Gear, Equipment, Recording & Off Topic 2 07-30-2001 06:47 PM
