Edge Zero swap? - Jemsite
post #1 of 7 (permalink) Old 03-26-2010, 03:10 AM Thread Starter
Edge Zero swap?
Hey, I would like to know whether it would be possible to swap the bridge of an Edge Zero equipped guitar for a Lo-Pro Edge bridge.
Vince~ is offline
post #2 of 7 (permalink) Old 03-26-2010, 01:33 PM
Re: Edge Zero swap?
i think it needs re-routing and possible mods to body depending on model. Be sure to do it only if you need it, otherwise is just a money waste.
nafigator is offline
post #3 of 7 (permalink) Old 04-16-2010, 12:47 PM Thread Starter
Re: Edge Zero swap?
How much would it costs to re-route the body? I just not used to the feel of the Edge Zero bridge and I would prefer to have the Lo-Pro Edge instead. By the way, is the route bigger or smaller for the Edge Zero?
Vince~ is offline
post #4 of 7 (permalink) Old 04-28-2010, 06:11 PM
Re: Edge Zero swap?
Interesting if Rich could add some info here. The spacing for the posts is wider on the Zero, so the post holes would have to be filled and new ones drilled for the standard Lo Pro. Also the body might need a re-route. I have 2 J Customs with Zero bridges, so i am interested in the mod for the Lo Pro.
darrenw5094 is offline
post #5 of 7 (permalink) Old 04-28-2010, 07:52 PM
Re: Edge Zero swap?
You know as much as I do. The studs would need to be moved, and the 2 spring setup may or may not work well if pinned to the outer holes in the block depending on how that angle effects the way the spring sits on the cross T of the ZPS.
Rich is offline
post #6 of 7 (permalink) Old 04-28-2010, 11:37 PM
Re: Edge Zero swap?
it might be better to just get a new body. i don't think the EZ spring system would work properly with an edge or lo-pro.
Homebake is offline
post #7 of 7 (permalink) Old 04-28-2010, 11:41 PM
Re: Edge Zero swap?
Scott was going to do this but I don't think he ever reported back if he got it done or not
http://www.jemsite.com/forums/f16/ze...-it-93269.html
Rich is offline
Edge III swap for another Edge model trem? lespaulreedsmith All Other Guitars (including Prestige) 39 12-21-2017 06:11 PM
JS100 bridge swap??? Edge Pro / Edge Pro II n7uqa Ibanez JEM, UV, JS & Other Signature Models 8 06-04-2009 11:35 AM
edge pro 11 swap slash_88 All Other Guitars (including Prestige) 1 10-27-2006 04:54 AM
Edge Pro II swap into an Edge Pro trem??? Flame_Virtuoso_6688 All Other Guitars (including Prestige) 0 07-18-2005 06:01 PM
