edge2 trem issues - Jemsite
post #1 of 25 (permalink) Old 05-13-2014, 04:45 PM Thread Starter
edge2 trem issues
OK so I have an rg320dxqm it had a Chinese tremolo on it and I found out it is supposed to have edge 2 trem so I bought one used and the high and low e strings don't line up on the neck one almost off the neck while the other is to far on the frets.
smokinguns3 is offline
post #2 of 25 (permalink) Old 05-13-2014, 06:46 PM
jb4674's Avatar
Reviews: 18
Re: edge2 trem issues
post pictures of the stock bridge and the new one.
Jimmy
jb4674 is offline
post #3 of 25 (permalink) Old 05-13-2014, 07:23 PM
RGTFanatic's Avatar
Jimmy
THIS^^^^
The year of your guitar is important here. There were three different trems use on the 320dxqm:
Lo-TRS II
Edge-Pro II
Edge III
You don't have an Edge 2. The Edge 2 only ever came out on one guitar in the late 80's....... a Vinnie Moore signature (VM1)
RGTFanatic is offline
post #4 of 25 (permalink) Old 05-13-2014, 08:02 PM
You don't need pics of the trem to align the strings on the neck, since one has zero to do with the other
Rich is offline
post #5 of 25 (permalink) Old 05-13-2014, 08:32 PM
RGTFanatic's Avatar
I think he has a stud spacing issue.
Although I didn't even think about a neck alignment problem.
post #6 of 25 (permalink) Old 05-13-2014, 08:56 PM
Occam's razor. What's the simplest and most common problem?
Rich is offline
post #7 of 25 (permalink) Old 05-13-2014, 11:49 PM
RGTFanatic's Avatar
Is that anything like Schrodingers cat???
post #8 of 25 (permalink) Old 05-14-2014, 12:19 AM
Probably?!
Thanks! I forgot the code for the 8 O -
Rich is offline
post #9 of 25 (permalink) Old 05-14-2014, 03:09 AM
If both the hi and lo E strings are nearly off the neck, could the problem not be the trem, but the nut?
I do know, that Jackson made a huge **** up with Adrian Smith SDX (the Indian made one), they installed an R3 nut, which gave a string spacing that was to wide, and the hi and lo E strings were very close to the neck edge, and at times, certainly around the 5th to 9th frets, "fell of the neck".
Over at JCF, many people say they have installed and R2, and solved the issue.
Maybe the trem isn't the only thing that has been changed. Is the nut correct. Reverting back to a Edge Pro II wouldn't solve the issue if the nut was wrong.
Mike_RG is offline
post #10 of 25 (permalink) Old 05-14-2014, 03:22 AM
Originally Posted by smokinguns3 View Post
one almost off the neck - while the other is to far on the frets.
That's just string alignment. If the trem is causing it I'm not sure how, and would need pics, but sounds more like the neck is out of line and needs to be shifted. Loosen the screws, muscle it over - without trying to break the guitar, and tighten the screws.
Rich is offline
post #11 of 25 (permalink) Old 05-14-2014, 10:37 AM Thread Starter
heres pictures the two in the middle are the new trem the one on guitar is the chinese one and its a 1997 body
post #12 of 25 (permalink) Old 05-14-2014, 01:41 PM
I assume that's a bolt on neck.
Just loosen the bolts enough that you can get to neck to wobble in the pocket when you push/pull on it. (Loosen the strings first, of course) then simply push the neck towards the high e-side (If you're holding the guitar in playing position; push down) then tighten the bolts and check the alignment.
It's not hard. Just don't go nuts pushing on the neck.
I had to do the same thing when I repaired my RG550.
Only on mine; the high E string was just about hanging off the board at around the 18th fret. :/
Meechy is offline
post #13 of 25 (permalink) Old 05-14-2014, 01:42 PM
I opened the box....poor kitty.
Meechy is offline
post #14 of 25 (permalink) Old 05-14-2014, 02:13 PM Thread Starter
Their isn't any room to move the neck
post #15 of 25 (permalink) Old 05-14-2014, 03:31 PM
Have you tried? Looks can be deceiving.
Meechy is offline
tremolo - help needed.
7V trem issues neilli Tech: Setup, Repairs and Mods 17 01-27-2012 11:12 AM
Why does everyone swap out edge2/3 for edge pro? MrMcSick Tech: Setup, Repairs and Mods 7 01-19-2010 02:39 AM
Trem claw screw issues. CaptainD00M Tech: Setup, Repairs and Mods 8 01-23-2008 08:04 PM
Trem stability issues, Edge m0p Tech: Setup, Repairs and Mods 9 09-18-2006 07:43 AM
Rg 7620 Trem issues... Dew_Riffic All Other Guitars (including Prestige) 2 05-20-2004 05:58 AM
