EMG installation question.. - Jemsite
post #1 of 9 (permalink) Old 12-27-2006, 06:44 PM Thread Starter
If any of you guys have an S series and have installed EMGs, help me out! I've got almost everything wired except for the jack. I can't get it in the hole where the original jack was; it's not long enough and there's not enough room to get the washer and nut in. Can you guys help me out? Thanks.
MaidenNH is offline
post #2 of 9 (permalink) Old 12-27-2006, 06:48 PM
Re: EMG installation question..
You should be able to use the original Ibanez output Jack. The switchcraft barrel jack that Ibanez uses is usually a stereo one. just unsolder the wires off the EMG jack and put them on the original Ibanez jack. The ground and live go where the ground and live wires were before and you wire the battery clip to the unused lug.
buddroyce is offline
post #3 of 9 (permalink) Old 12-27-2006, 06:53 PM Thread Starter
I thought about doing that but EMG covered one of the connections with this little rubber sleeve that I can't get off. Maybe I'll give it another go.
MaidenNH is offline
post #4 of 9 (permalink) Old 12-27-2006, 06:54 PM
Then just cut it off
C.Thep is offline
post #5 of 9 (permalink) Old 12-27-2006, 06:56 PM Thread Starter
Good point.
MaidenNH is offline
post #6 of 9 (permalink) Old 12-27-2006, 06:59 PM
I guess I forgot to mention the cutting off part..
post #7 of 9 (permalink) Old 12-27-2006, 10:55 PM Thread Starter
Ok so I got it installed and working, but now all I'm getting is a clean sound. No distortion at all.
MaidenNH is offline
post #8 of 9 (permalink) Old 12-27-2006, 10:59 PM
No distortion at all usually means that you're not getting any or enough power to the pickups. I know this may sound strange, but have you tried a different battery? If you have, double check to make sure that your pickups are in deed getting power. I had the same problem once when I installed a set of EMG 707/81-7's in a RG1527 for a client once. Fixed the problem with a new 9v battery. (the dumb thing was the first battery was also fresh out of the package... I guess it depends on how long it's been sitting on the store shelf.)
post #9 of 9 (permalink) Old 12-27-2006, 11:09 PM Thread Starter
I tried 3 different batteries; no luck.
MaidenNH is offline
Problems with EMG 85 pickup installation LonePhantom Pickups & wiring 12 08-23-2005 05:03 PM
Yet another EMG question :) Jslegacy Pickups & wiring 2 03-31-2003 12:29 PM
EMG pickup installation trouble nocebo Pickups & wiring 4 03-26-2003 06:59 AM
EMG Afterburner question Break Zero Pickups & wiring 4 03-12-2003 12:00 PM
Hello again & question on EMG 707s. - Where can I get a good revsharp777 Gear, Equipment, Recording & Off Topic 3 01-14-2001 12:10 AM
