esp - the best? - Jemsite
post #1 of 39 (permalink) Old 04-21-2002, 12:16 PM Thread Starter
esp - the best?
hi
which is the best (your opinion, not facts) esp/ltd guitar?
does the floyds on the ltd:s stays in tune or is it like a trs?
thanks...
johan15 is offline
post #2 of 39 (permalink) Old 04-21-2002, 02:50 PM
esp
I don't know what the best is, but the trems on LTDs SUCK!!! If you do a search you'll find countless whinings about mine I ended up blocking the damn POS :angryfire:
yurich is offline
post #3 of 39 (permalink) Old 04-21-2002, 03:07 PM
esp
I've heard good things about the sig. models, and I know someone in London who uses a custom model (I think) that's very nice. *But I've heard a lot of complaints too. *I'd recommend them for hard-tail, but I'm not sure about the Floyd-ed ones. *Basically, try 'em for yourself. *See which side you're sitting on.
Two hands31 is offline
post #4 of 39 (permalink) Old 04-21-2002, 06:11 PM
esp
I have an ESP M II Custom with an original Floyd that is great but I havent had much experience with the LTDs.
gitarguy is offline
post #5 of 39 (permalink) Old 04-21-2002, 08:40 PM
esp
The LTD's are so so guitars. *Although I once tried out an ESP MH Deluxe in a store and it was awesome. *All of their deluxe and custom stuff seems good from what ive seen. *They are hard to find in this area of Michigan though :angry:
Guitarlos2 is offline
post #6 of 39 (permalink) Old 04-22-2002, 06:22 AM
Super Moderator
jono's Avatar
esp
The best Ltd imho (lots of abbr ) *is the SRC500 Stephen Carpenter one. There's no trem to go wrong or out of tune and other than that they seem really solid guitars. I've considered picking one up, but I don't get on with either the body shape to well, nor the tunamatic
the best ESP guitar I've tried was one of the KH2 relics. I normally don't go for thru-neck construction but this one played fantastically and sounded great through the stores Line 6 AXSYS2 I guess the active pickups keep it sounding bright and tight
jono is offline
post #7 of 39 (permalink) Old 04-23-2002, 07:48 PM
esp
I like the Horizons, with no trem. But then again I'm a "no trem" kinda guy :biggrin:
Polaris20 is offline
post #8 of 39 (permalink) Old 04-24-2002, 09:17 AM Thread Starter
esp
how much is the horizons (with and without trem) ?
sorry, but a yen is not in my mind
johan15 is offline
post #9 of 39 (permalink) Old 04-24-2002, 09:28 AM
esp
Horizons only come (in the states) without a trem. I think they usually run between $400 to $600. Then there's the H1000, but I don't think I'd pay $900 for a Korean guitar.
post #10 of 39 (permalink) Old 04-24-2002, 10:30 AM
Super Moderator
jono's Avatar
esp
Yep as far as I know in the LTD range the Horizon is known as the H series and comes only with a fixed bridge (tunamatic/stoptail) When the Horizon bodyshape has a floyd rose licensed trem ESP/LTD change it's designation to the "MH"
They range from the cheapest H-100 and MH-100 for just a few hundred USD right up to custom shop models from Japan which are thousands of USD.
jono is offline
post #11 of 39 (permalink) Old 04-24-2002, 10:45 AM
esp
look on ebay for ESP Customs, they are generally under $700 and they are the highest quality of guitars you can get. Make sure they say custom shop behind the headstock. All the esp customs i played have been better than Jem7vwh's which is ibanez's best model (besides the RGT, that guitar is just too sweeeeeet).
WYLD STALLYNS is offline
post #12 of 39 (permalink) Old 04-24-2002, 11:24 AM
Super Moderator
jono's Avatar
esp
I agree with WYLD STALLYNS, there've been several ESPs on ebay I've considered even though they're not my usual style of guitar simply because they're suberb guitars at frankly rediculously low prices !!!
jono is offline
post #13 of 39 (permalink) Old 05-02-2002, 01:07 PM Thread Starter
better then jvwh ? well, if so I must take a lokk at´em...
johan15 is offline
post #14 of 39 (permalink) Old 05-02-2002, 01:30 PM
anyone who says this is not worth the $500 BRAND NEW is lying...
I honestly think they make some of the best finishes for the buck
yurich is offline
post #15 of 39 (permalink) Old 05-02-2002, 01:47 PM
if it's not showing up (why?), enter this:
.http://jemsite.insomnia-vhosting.com...img/1small.jpg
yurich is offline
base plate , body shape , custom shop , duncan designed , fixed bridge , floyd rose , gauge strings , guitar shop , killer guitar , korean guitar , neck shim , playing guitar , spring cavity , stephen carpenter , string lock , trem arm , truss rod , truss rod cover
