Fender 1952 telecaster question!! Help please :) - Jemsite
post #1 of 6 (permalink) Old 09-21-2009, 06:21 AM Thread Starter
Hey guys,
I always wanted a 1952 vintage fender telecaster but I've just found out that it has a gloss neck
Whenever I've played gloss on fenders before it feels really sticky and horrible to me.
Is this something that I should let effect my decision in getting one or not? I hear with playing time it wears down.
I believe the hot rod version is a satin finish
sharpant is offline
post #2 of 6 (permalink) Old 09-21-2009, 07:55 AM
Re: Fender 1952 telecaster question!! Help please :)
If it works for you, then just sand the neck and apply tung oil instead. Kind of money-out-of-the-window for re-sale value, but what the hell, you only live once.
Jacob K is offline
post #3 of 6 (permalink) Old 09-21-2009, 11:55 AM
Ever consider building one yourself? I just finished building 2, one for myself and one for a bandmate. It was very easy and rewarding, and they cost between 250-300 bucks for me to make them. The one that I built for myself is a '52 style, and while I happen to like the gloss finish on Fender necks, there were several '52 re-issue necks on the bay that had a satin finish when I purchased mine. Not only did I save a ton of money by just buying parts (I got everything from www.guitarpartsonline.com and the bay) but I was able to buy the parts I like, instead of dealing with whatever crap fender decided to throw on it.
If this sounds like something you're not interested in, then sanding and oiling the neck is your best bet.
As Hell Broke Loose is offline
post #4 of 6 (permalink) Old 09-22-2009, 12:56 AM
Sandpaper is your friend.
DavyH is offline
post #5 of 6 (permalink) Old 09-22-2009, 01:18 AM
Ayrton's Avatar
Nothing a little sand paper and elbow grease can't solve.
Ayrton is offline
post #6 of 6 (permalink) Old 09-22-2009, 07:57 PM
I have one. The finish will smooth out over time, but if you cant wait you can knock down the gloss pretty easily. You dont have to take all the finish off, just knock down the gloss. I think some guys use very fine steel wool, or very fine sandpaper. It doesnt take much.
Also, if you're looking into the Hot Rod version, remember it will have a flatter, more modern fretboard radius, mini-humbucker, and hotter single coil. Depending on the sound you are going for, it may or may not be for you. I bought the more period correct version, with the 7.25" radius and vintage pickups.
Good luck, you'll enjoy either one!
Blacksunshine is offline
FS - Fender Telecaster Vaibanez Classified Ads: Guitars and Gear 0 03-08-2009 06:40 PM
FS/T: Fender USA Telecaster Speedy Fingers Classified Ads: Guitars and Gear 3 05-07-2008 09:51 AM
FS:Fender Telecaster elcid Classified Ads: Guitars and Gear 3 03-22-2008 04:28 PM
FT UK : Fender US Telecaster (95) smc Classified Ads: Guitars and Gear 2 03-26-2006 08:21 AM
Fender Telecaster Wound All Other Guitars (including Prestige) 2 01-11-2005 10:05 AM
