Floyd nut dilemma - Jemsite
post #1 of 4 (permalink) Old 09-06-2012, 11:10 AM Thread Starter
Floyd nut dilemma
Hi all,
You guys are always a big help. I figured also that this is the place to ask about Floyd Roses
I pretty much have had Floyds on all of my guitars since I was a kid but I have one with a strat trem that I recently bought. It has a neck on it that is set up and playing great with the guitar, and I donít want to mess with it. However, itís a Floyd nut. I have been playing without the lock blocks, and using locking tuners. Works great but I get this really loud high-pitched harmonic when I play the open high E string.
I tried the foam, and I canít get used to it. I also have one of those nut replacements that fit Floyd routes but I have to sand the slot a lot and the setup now is right with the Floyd nut. Also, this Floyd nut was filed down a little underneath so I canít really swap for another nut that I have laying around to see if the harmonic isnít there.
Has anyone just used the lock blocks and tightened them by hand just to solve this? I definitely donít want to tighten with the allen wrench in case I have to retune, which is why the fine tuners are so crucial on the Floyd. Any help would be appreciated. Thanks,
Pete
pforsell is offline
post #2 of 4 (permalink) Old 09-06-2012, 06:56 PM
jb4674's Avatar
Reviews: 18
Re: Floyd nut dilemma
What gauge is the high e string? Have you tried using a thicker gauge? The pinch you might be hearing is the string getting caught in the nut somewhere. I would also try filing the high e string slot on the nut and putting graphite on all slots to allow the strings to return to pitch, that should help.
Post your findings
Jimmy
jb4674 is offline
post #3 of 4 (permalink) Old 09-07-2012, 11:05 AM Thread Starter
Thanks Jimmy. So you can put graphite powder on the a Floyd nut? That would be great it it worked. Thanks again,
Pete
pforsell is offline
post #4 of 4 (permalink) Old 09-07-2012, 11:59 AM
Reviews: 13
Pete
In the past when ive done it, all i do is get a pencil and just give it a little 'dab'
RyansJem is offline
floyd rose
I Have A Dilemma Agenthoover Ibanez JEM, UV, JS & Other Signature Models 36 08-30-2011 10:33 AM
Im in a Dilemma! RG777 Gear, Equipment, Recording & Off Topic 17 08-11-2007 05:39 AM
Jem Dilemma! What would you do? Alexeh Ibanez JEM, UV, JS & Other Signature Models 25 05-27-2007 06:04 AM
dilemma here.. help please spkenn5 Pickups & wiring 0 11-23-2006 10:28 AM
Dilemma invisible_kid_ Ibanez JEM, UV, JS & Other Signature Models 43 06-13-2005 04:47 PM
