fret buzz on low strings - Jemsite
post #1 of 15 (permalink) Old 06-30-2009, 02:03 AM Thread Starter
ebh
Hi
I get an annoying fret buz on the low strings (E, A, D, G). I tried raising the action with no result. The truss rod adjustment seams fine. I get buzz only on heavy strumming/picking and it's all over the fret board, especially in the "middle" (frets 5 - 15).
The guitar is a RG 2550Z.
Thanks!
ebh is offline
post #2 of 15 (permalink) Old 06-30-2009, 03:55 AM
Re: fret buzz on low strings
hey dude, im getting he same problem with my guitar, but on the 6th string. ive taken it to MANY places, and they say that its "unfixable"! my guitar is an RGT320Z
ew94 is offline
post #3 of 15 (permalink) Old 06-30-2009, 04:17 AM
what is the curve in your neck like?
i own an rg2550z. my neck curve is very slight, almost flat. my action is pretty low, but it can go lower. i get very minimal buzzing around the 3-5 fret area on the low E but so little it's barely worth mentioning.
it sounds like your neck needs to be adjusted. what gauge strings do you use?
Homebake is offline
post #4 of 15 (permalink) Old 06-30-2009, 04:26 AM Thread Starter
ebh
I use the standard gauge strings (9-42). I don't get buzz if I play smooth/lightly. On normal gain is not noticeable. I can hear it unplugged.
ebh is offline
post #5 of 15 (permalink) Old 06-30-2009, 10:48 AM
GAZ
A slight buzz is inevitable with a very low action/light strings but it shouldn't be audible through the amp. I'm assuming you tune to concert pitch ? If the buzz is worse in the middle frets you need more neck relief, i.e. you need to loosen the truss rod slightly. If you play aggressively try a set of 9-46 strings !
GAZ is offline
post #6 of 15 (permalink) Old 06-30-2009, 12:53 PM Thread Starter
ebh
I tried (a lot of) truss rod relief, but the buzz was still there, even with pretty high action (about 3mm, maybe even more on the low E). No success.
Now I got it back where it was in the beginning (pretty low action and only a slight neck relief) and I'll try to get used to/over the buzz.
It's not audible through the amp with average/high gain. But with low gain and especially on clean it is audible (not a lot but you can hear it's there) on some notes/frets/strings. I don't play concerts, I am a home user
I boght some d'addario 9-46's today but I will change them when the ones I have now get used (enough) or at least one breaks. I just put some ghs 9-42 yesterday (thought it could be the stock strings, but it didn't solve anything).
ebh is offline
post #7 of 15 (permalink) Old 06-30-2009, 07:48 PM
Reviews: 120
Maybe you need to shim the nut a bit?
LonePhantom is offline
post #8 of 15 (permalink) Old 07-01-2009, 04:51 AM
GAZ
That will only affect the open strings !
GAZ is offline
post #9 of 15 (permalink) Old 07-01-2009, 05:24 AM
you're either missing something big, your guitar has a freakish problem or you're paying too much attention to the buzz.
Homebake is offline
post #10 of 15 (permalink) Old 07-01-2009, 09:05 AM
This really does sound like a neck relief issue. How much time did you give it when you loosened the truss rod. It may not react instantly.
southpaw_lefty is offline
post #11 of 15 (permalink) Old 07-01-2009, 01:10 PM Thread Starter
ebh
I came to a conclusion. It's an acceptable amount of buzz (when i strum/pick gently I don't get it and neither when I use my fingers). I can barely hear it through the amp on the humbuckers with normal/blues gain (with high gain I can't hear it at all, no matter what pup/combination I use).
As it is my first over 1000eur guitar, I had the highest expectations out of it and I expected it to be perfect - as in really low action and no fret buzz, no matter how hard I would pick/strum it.
Thanks for all your replies!
ebh is offline
post #12 of 15 (permalink) Old 07-12-2009, 11:15 PM
no, shimming the nut will raise the action of all strings across all frets...
AlkyHauler is offline
post #13 of 15 (permalink) Old 08-14-2009, 11:09 AM
as soon as you press a string to the board the nut height means nothing.
spider murphy is offline
post #14 of 15 (permalink) Old 08-14-2009, 12:54 PM
Dino's Avatar
Get a professional setup and level, then just play it and it will go away.
Dino is offline
post #15 of 15 (permalink) Old 08-14-2009, 05:24 PM
Check that the frets follow correctly the arch of the Fretboard/Neck. I was just testing what Rich Suggests on his site and noticed that after I got my acoustic refretted the guy didn't arched the fretwire correctly and that's why my guitar is buzzing after I moved from one side of the continent to the other. And even when I increased the Gauge from 9-42 (I had electric guitar strings) to a 10-47.
einarabelc5 is offline
buzz , fret , rg2550
always fret buzz after changing strings SandmaN211 Tech: Setup, Repairs and Mods 4 06-12-2007 07:40 AM
Fret Buzz problem, lower 3 strings only. SidewinderINC Tech: Setup, Repairs and Mods 6 04-02-2006 03:12 PM
Fret buzz on RG560 (only on open strings... hmm?) Stygian Tech: Setup, Repairs and Mods 7 12-29-2005 04:37 PM
Fret buzz on 14 fret (A + D strings)please help Dave Goodland Tech: Setup, Repairs and Mods 3 12-18-2002 01:30 PM
advice needed for strange fret-buzz on my UVGR - nasty buzz Superuser Tech: Setup, Repairs and Mods 8 02-19-2002 04:35 AM
