Fret Buzz need help! - Jemsite
post #1 of 9 (permalink) Old 03-04-2008, 01:54 PM Thread Starter
Hi all,
I've got an RG2570 (2003 model) that is a dream to play, nice low action and great sound.
I've changed the strings (at a shop) and my guitar is now riddled with buzz all over the place, the bridge is as it should be - flush to the body - and the action was as I had it, but now its buzzing like crazy all over the neck.
It didn't do this before, there was a slight buzz that I quite like, but not as bad as now that makes playing not very nice.
Any tips? Is this a truss rod adjustment? I dont wan't the action a mile off the neck and the nut seems to be fine, this is just after this latest string change.
Thanks everyone
wandereruk05 is offline
post #2 of 9 (permalink) Old 03-04-2008, 02:05 PM
jb4674's Avatar
Reviews: 18
Re: Fret Buzz need help!
What kind of strings were on before and what strings are there on now? Was the gauge changed to a different gauge?
Jimmy
jb4674 is offline
post #3 of 9 (permalink) Old 03-04-2008, 02:06 PM
the bridge shouldn't be flush with the bdy. the knife edges of the trem should be(more of less depending on action). if the buzz is still pretty bad, loosen up the truss rod a bit until it relieves the buzzing, not too much, tho. if you do what can happen is that if you loosen it up too quickly, the string tension will increase and it will take longer for the neck to settle.
rich
rty13ibz98 is offline
post #4 of 9 (permalink) Old 03-04-2008, 02:10 PM Thread Starter
hi same gauge - even the same strings!!! i dont use anything else but Dean Markley blue steel - haven't done for about 3 years.
I've 9-42s on this. knife edge is flush - bridge was reaching for the ceiling a while back but i sorted that with the screws in the back a while before re-string.
could it still be the truss rod? (one of the strings was off for a couple of days)
thanks
post #5 of 9 (permalink) Old 03-04-2008, 02:28 PM
yeah, i would suspect it needs a truss rod adjustment. if that doesn't fix it, it needs the neck shimmed.
rich
post #6 of 9 (permalink) Old 03-04-2008, 02:39 PM Thread Starter
at the nut or the joint of the body?
this really annoying as its been fine and now its just horrible.. truss rod slightly helped but still quite bad.. i can get it so its just the low E thats making the rattle = all the way up the neck and the then some frets quite bad from 12 onwards
post #7 of 9 (permalink) Old 03-04-2008, 02:43 PM
under the neck joint/heel. just a small shim under the neck side bolts(not the humbucker side) should create a bigger gap under the strings, while still keeping the tension the same. just a small shim, you don't want to make it to where you have to drop the trem lower into the trem route.
rich
post #8 of 9 (permalink) Old 03-04-2008, 02:44 PM
jb4674's Avatar
Reviews: 18
Raise the trem a bit and it should fix the problem.
Jimmy
jb4674 is offline
post #9 of 9 (permalink) Old 03-04-2008, 02:45 PM Thread Starter
okie dokie - dont have the tools on me now this is such a pain - trying to sell the guitar the moment as well =/
ps thanks for the help much appreciated!
dean markley , dean markley blue , dean markley blue steel , markley blue steel , neck joint , neck shim , rod adjustment , string tension , truss rod , truss rod adjustment
Fret buzz at 2nd fret aj_foes Tech: Setup, Repairs and Mods 2 04-19-2006 04:06 AM
How to elimate fret buzz completely in a guitar? zerolight Tech: Setup, Repairs and Mods 16 10-27-2003 12:06 PM
Fret Buzz from frets 11-14...? Drew Tech: Setup, Repairs and Mods 8 02-18-2003 11:02 AM
Fixing Fret Buzz - on only a single note! mechanyx Tech: Setup, Repairs and Mods 7 04-03-2002 03:15 PM
Fret Dressing How To - Not for the weak of stomach Kyle Odom Tech: Setup, Repairs and Mods 6 08-23-2001 04:06 PM
