Fretboard cleaning - Jemsite
post #1 of 11 (permalink) Old 05-29-2006, 11:16 AM Thread Starter
Fretboard cleaning
there seems to be some kind of waxy buildup on the frets, when I try using a toothbrush it just makes it clearer, and it seems possible to scrape it off. What tools do you people use to remove this sort of thing without damaging the fretboard?
NeglectedField is offline
post #2 of 11 (permalink) Old 05-29-2006, 11:23 AM
Re: Fretboard cleaning
Try a mild heat source and then wiping it off. I hold a lighter about an inch away.
Mr.WizardNeck is offline
post #3 of 11 (permalink) Old 05-29-2006, 12:31 PM
Maple, rosewood, ebony...?
marianozz is offline
post #4 of 11 (permalink) Old 05-29-2006, 12:53 PM
JJEMMER777's Avatar
- that's a scary thought!
Like ozz said, we need to know which type of wood it is as the cleaning method varies.
JJEMMER777 is offline
post #5 of 11 (permalink) Old 05-29-2006, 01:20 PM
Its not that much...
I could never find out what to use on maple, dirt just goes deeeep and sanding clean will get you a slight scallop
Lighter fluid, mild steel woolin on maple...
Steel woolin with the grain, bore oil and elbow grease on rosewood and ebony...
i usually do a lil across the grain on rosewood if the gunk is too much, i do a lot of passes with the grain to remove traces, with mi nail up against the frets, its tiresome, annoying and gives you sore fingertips, but the results are worth it...
post #6 of 11 (permalink) Old 05-29-2006, 01:30 PM
JJEMMER777's Avatar
Maple is a actually very easy to clean UNTIL the finish begins to wear off. Just wipe her down. I wouldn't steel wool it as that wears on the finish. Once the finish wears off dirt just goes into the pours like your saying. Only way I know to clean it after that is to sand it and get it refinished. PIA!!!!
Also, make sure you use .0000 steel wool on your rosewood/ebony and linseed oil works great as well as bore oil.
BTW -
I wouldn't recommend using lighter fluid with Wizardnecks lighter method
post #7 of 11 (permalink) Old 05-29-2006, 01:39 PM
You mean finished maple, like, clearcoated... i hate that, i meant raw maple
And linseed oil sucks!!! its like tung oil, it builds up... great for finishing, but not for oiling dark boards!
post #8 of 11 (permalink) Old 05-29-2006, 01:43 PM
JJEMMER777's Avatar
Ah gotcha. Well, if your going with ~RAW~ maple your always going to have that dirty bloch problem. Then again, a lot of people like that aged look. I prefer mine clean
post #9 of 11 (permalink) Old 05-30-2006, 08:23 AM Thread Starter
Oh sorry, I should've said.
It's rosewood I think. RG321 '03/'04 model.
post #10 of 11 (permalink) Old 05-30-2006, 08:45 AM
Check this at Rich's:
http://www.ibanezrules.com/tech/grunge/grunge_1.htm
Awesome step by step explanation...
post #11 of 11 (permalink) Old 05-30-2006, 09:21 AM Thread Starter
Excellent, cheers. That's exactly the sort of build-up that's on my fretboard.
steel wool , tung oil
Cleaning fretboard with Windex..Good/bad? KissMyAxe Ibanez JEM, UV, JS & Other Signature Models 25 06-04-2006 06:00 AM
Just a few questions about fretboard cleaning Dr Mindcrime Tech: Setup, Repairs and Mods 6 10-26-2004 11:53 PM
Fretboard cleaning without steel wool Pesso Tech: Setup, Repairs and Mods 3 09-13-2004 01:34 AM
Fretboard Cleaning DiminisheD-7th All Other Guitars (including Prestige) 2 08-23-2004 06:01 PM
Cleaning of a Jem7vwh fretboard jklarsen Tech: Setup, Repairs and Mods 3 07-15-2002 01:44 PM
