FRM250MF - F-spaced or not? - angled pickups! - Jemsite
post #1 of 2 (permalink) Old 09-10-2017, 10:56 AM Thread Starter
Hi all,
I'm looking to replace the Air Classic pickups in my FRM250MF with something a little more tight and focused. I think I'll get a crunch lab unless anyone has any better suggestions for working with a high gain ENGL amp?
My issue is whether I require F-spaced pickups? The string width is quite big, the bridge is a 'Tight-Tune Fixed' however the pups are angled and as such the string width is essentially reduced?
Does anyone have any idea if I require F-spaced or not? I've contacted Ibanez but no response as of yet!
Thanks loads!
PS - This is my first post since 2013 - been lurking for years!
Fantomas_UK is offline
post #2 of 2 (permalink) Old 09-11-2017, 05:52 PM
Reviews: 120
Re: FRM250MF - F-spaced or not? - angled pickups!
Have you measured the pole-piece spacing, or pulled the pickups and looked at the baseplate? That'll give you your answer. From memory DiMarzios have an "F" stamped on them for F-spacing, and besides that, the simple way to get your answer without pulling apart anything is to measure the pole-pieces.
LonePhantom is offline
angled , f-spaced , fireman , frm250mf
Frm250mf and a loop station. m t soule Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 1 01-27-2015 01:40 AM
Frm250mf and a loop station. m t soule Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 0 12-14-2014 07:52 PM
rg350 pickups, both f spaced, both normal or only one f spaced? Mike_Thrash Pickups & wiring 11 04-15-2013 05:44 PM
F-spaced pickups eg Pickups & wiring 9 05-21-2007 09:48 PM
F spaced pickups for an RG? rchip All Other Guitars (including Prestige) 6 09-13-2005 07:12 PM
