Gibralter bridge is driving me mad, please help!! - Jemsite
post #1 of 2 (permalink) Old 03-14-2007, 03:08 PM Thread Starter
Unhappy Gibralter bridge is driving me mad, please help!!
I've had my black RGA121 for a little while now. I first started to notice something strange on my low E. The string (though retaining normal string tension) sounds flubby when I pluck it. I'm using 10-52 DRs by the way if that makes a difference. None of the other strings experience this problem, only the low E.
I only noticed today that, when the ball of the string sits, it is different on the low E. All the ball ends on the other strings are facing up so you can see through the hole. The low E ball is kind of sideways, which led me to believe it wasn't sitting properly in the saddle. I pulled on it as hard as I could, tried a difference string and no luck.
This problem is really driving me nuts. I thought for a second that it was maybe my pickups, but none of the other strings have the same problem. So is my claim valid??
Next, would a Gibralter Plus bridge from the new RGAs fit on this guitar without modding?? Are they different than the regular gibralters?? I've read of other guys having issues with thicker strings fitting through the saddle on this guitar. PLEASE, any help is appreciated!! thanks!
-Joe
mityjoeyoungxnj is offline
post #2 of 2 (permalink) Old 03-14-2007, 03:50 PM Thread Starter
Re: Gibralter bridge is driving me mad, please help!!
Ok I put a smaller gauge on and it definitely helped out...!!
I might still try a gibralter plus bridge, but don't know if it's worth hunting one down. Might be hard considering how new they are.
-Joe
string tension
Installing peizos into an edge pro bridge. merman_93 Tech: Setup, Repairs and Mods 12 01-01-2009 11:15 AM
Bridge grounding issue on RGA121 Vinco Pickups & wiring 6 09-29-2005 09:00 AM
Breed neck / bridge difference in bridge position marino Pickups & wiring 2 05-25-2005 08:43 PM
Is this going to be easy??? - Bridge replacement for RG421 ChrisReedSmith Tech: Setup, Repairs and Mods 0 04-18-2002 08:25 AM
New P'ups in my JEM - ...bridge and middle replaced... kennydoe Ibanez JEM, UV, JS & Other Signature Models 2 04-10-2001 10:55 PM
