Hairline crack on neck joint - Jemsite
post #1 of 3 (permalink) Old 04-12-2008, 04:31 PM Thread Starter
is it possible for these to be more than just finish crack, ie become a wood crack and destroy the guitar?
thanks.
acdc51502112 is offline
post #2 of 3 (permalink) Old 04-12-2008, 04:40 PM
Jaden's Avatar
Re: Hairline crack on neck joint
if the necks had a bit of abuse then the finish crack can become a crack in the wood also.
Jaden is offline
post #3 of 3 (permalink) Old 04-12-2008, 04:41 PM
acdc51502112,
Almost every one of my IBZ's (Jems included) have these cracks. Some of which are through the wood. I beat my guitars on the road a ton, and they still hold up after all these years. So although the cracks may look rough... I haven't had any major problems with instability of the guitars.
Check out pix of Vai's guitars. I'm sure his neck pocket cracks are through the wood as well.
You'd have to do some harsh beating on the guitar to cause any major damage with those cracks. The strength in the neck pocket is the screws holding the neck on. Be sure to check them from time to time, and tighten.
Hope that helps answer your question.
Joe
www.LFire.com
www.myspace.com/lfiremusic
www.myspace.com/joerileymusic
shredhead74 is offline
neck pocket crack , neck pocket cracks
aanj neck joint screws tt0511 Ibanez JEM, UV, JS & Other Signature Models 10 10-27-2006 12:14 AM
for trade , ibanez usrg30 j.arledge Classified Ads: Guitars and Gear 2 03-07-2006 09:14 PM
Painted neck? Sanded neck? Drache713 All Other Guitars (including Prestige) 28 12-24-2005 11:45 PM
"vertical" crack at the scarf joint? marianozz Tech: Setup, Repairs and Mods 6 07-14-2004 04:15 PM
Any suggestions for repairing hairline crack in neck? john1880 All Other Guitars (including Prestige) 12 06-09-2004 12:04 AM
