Hardened Knife Edge on Edge - Jemsite
post #1 of 11 (permalink) Old 11-23-2011, 10:09 PM Thread Starter
I'm slowly getting my ibbys to have the same action across all guitars. I'm tweaking truss rods and adjusting bridge posts. So earlier I was raising the treble side of an Edge and BAM! the bridge leaps off its tracks and is sitting way high and at a bad angle. I think, "what the [email protected]#$?"
Before:
And after looking around my floor to find the piece:
ashbass is offline
post #2 of 11 (permalink) Old 11-23-2011, 10:40 PM
Re: Hardened Knife Edge on Edge
Don't do that. Why would you do that?
Don't do that.
dcord is offline
post #3 of 11 (permalink) Old 11-23-2011, 11:26 PM
This is why you are suppose to take the tension completely off the bridge before making post adjustments. I'm not saying I haven't made small tweaks myself with it fully strung but it isn't a good idea. It's about 80 lbs of pressure when it's strung.
gideond is offline
post #4 of 11 (permalink) Old 11-24-2011, 01:32 PM
RGTFanatic's Avatar
Just call "SUPER Rich". He'll rescue you!!!
Now you know better though.....lesson learned and at a cheap price too.....
RGTFanatic is offline
post #5 of 11 (permalink) Old 11-24-2011, 01:49 PM Thread Starter
Actually, from what I recall reading somewhere on the forum, the posts are designed to be adjusted while under tension. This particular one was 24 years old though and finally gave in.
I might push the trem all the way down next time to lessen some tension, but I'll never completely detune, make an adjustement, and then retune. Again and again and again. Tweaking is pain in the @ss enough already without having to tune a locking bridge back to concert pitch 20 times at a sitting.
Thanks for the comments though.
ashbass is offline
post #6 of 11 (permalink) Old 11-24-2011, 02:00 PM
I agree, it would be a total pain. I usually release most of the string tension but not all and then make the adjustment until it's roughly where I need it. Then I'll tune up and tweak it from there. Once you get the post set correctly the first time you really shouldn't have to be adjusting them very often at all, especially if they have a locking stud.
gideond is offline
post #7 of 11 (permalink) Old 11-24-2011, 02:10 PM
All completely unnecessary on any Edge [except EP2/ED3, they're junk]. They are absolutely made to be adjusted at pitch.
There are many reason the heads snap on these. Usually they crack vertically, that's the first one I've ever seen where the head popped off, but it's not like it popped off because adjusting it cut through it. Parts break, sometimes without reason, and when they're 20+ years old, you should expect some things need replacing.
Rich is offline
post #8 of 11 (permalink) Old 11-24-2011, 02:23 PM Thread Starter
I think it was a post by Rich.
ashbass is offline
post #9 of 11 (permalink) Old 11-24-2011, 10:58 PM
I've adjusted my guitars at-pitch since I got my first Ibanez in 1991. Adjusting them can be tricky enough - if it had to be tuned/de-tuned every time to adjust the trem...? There's no way in hell I'd own these guitars, and I've got five of them now.
Every time I change my strings I service the tremolo. It must be maintained, which is to say that it needs to be cleaned and lubricated. Chap-Stick on the posts at the knife-edge minimizes binding against the posts. Periodic knife-edge maintenance, and removing the posts and using lubricant (sparingly! I spray it on a Q-tip and then apply it) on the post threads is also good practice... 20+ years later, my oldest Ibanez (an RG770DXLB) is in near-mint condition with all its original bits and pieces.
And as Rich said... after 20 years, expect some parts to fail. It just happens. Having been a fan of classic guitars for 30+ years, I've learned to take maintenance to the next level to keep my stuff in above-average condition. It takes little extra time and the long-term payback is obvious.
Bluestreak is offline
post #10 of 11 (permalink) Old 11-25-2011, 08:19 PM
OMG I wasn't expecting to read that!
Does that include the Edge Zero and Edge Zero 2?
Typhon is offline
post #11 of 11 (permalink) Old 11-25-2011, 08:21 PM
EZ and EZ2 have the hardest knives and studs of them all.
Rich is offline
edge , post
Are Ibanez Edge Pro trems case hardened steel like the OFR's? deathmetallist3 All Other Guitars (including Prestige) 4 07-17-2010 02:42 PM
Edge Lo Pro knife edge remauto1187 Tech: Setup, Repairs and Mods 0 05-04-2009 10:20 PM
knife edge? rich2k4 Tech: Setup, Repairs and Mods 3 03-30-2006 08:01 PM
Edge and Lo Pro Edge Bridges: Are they hardened steel? Given to Fly Tech: Setup, Repairs and Mods 2 04-12-2003 09:37 PM
Edge bridge repairs - post & knife edge jd Tech: Setup, Repairs and Mods 6 12-09-2002 05:48 PM
