HELP! The Edge Pro On my new RG2550e has broken 4 high E strings!! - Jemsite
post #1 of 5 (permalink) Old 01-21-2006, 05:33 PM Thread Starter
Exclamation HELP! The Edge Pro On my new RG2550e has broken 4 high E strings!!
Hey, i got a beautiful RG2550 for Xmas but whenever i put the high e string up to full tension it breaks. The factory d'addario .009 broke at the nut when i was stretching it in. I bought another d'addario 9, same again but at the machine head. Then i bought another 9 and that broken when i plucked it gently after locking the nut. Finally, i bought d'addario .010's and set it up but the high e string broke at the machine head when i did a slight bend. All other strings are fine and im almost in tears because i havent been able to play it since it was delivered a week ago. Any ideas why i need all the help i can get !
Thanks Elliot,
Neader is offline
post #2 of 5 (permalink) Old 01-21-2006, 05:59 PM
Re: HELP! The Edge Pro On my new RG2550e has broken 4 high E strings!!
Thanks Elliot,
Go to ibanezrules.com (banner above) and read the tech section about the Edge pro trem and how to set it up probably.
Regards
Andrť
fettouhi is offline
post #3 of 5 (permalink) Old 01-22-2006, 02:37 PM Thread Starter
it is set up, ive got the manual
Neader is offline
post #4 of 5 (permalink) Old 01-24-2006, 08:43 AM
That is wierd and very unfortunate and I feel bad for you. That would be terribly frustrating.
Is it breaking at the same place EVERY time ? Do you use a tuner to tune it ? And what tuning are you using ? Standard ? E A D G B E I ask because if you're guessing or tuning by ear maybe you're tuning it too high maybe ? The added tension would make you break strings easier, especially if they are breaking at different points.
GTR-MAN is offline
post #5 of 5 (permalink) Old 01-24-2006, 03:30 PM
if all else fails , exchange it
guitardevil2005 is offline
edge pro trem
fret buzz on high e & b strings mc_tharow Tech: Setup, Repairs and Mods 7 11-04-2013 02:09 PM
EDGE Pro problem - saddles goe "tic tic" when I bend the high strings gitarrero Tech: Setup, Repairs and Mods 11 05-02-2012 05:58 PM
ESP M-201, strings pulling the bridge up too high.. Clydefrog All Other Guitars (including Prestige) 3 06-07-2007 02:42 PM
Sitting guitar with broken strings Fry Tech: Setup, Repairs and Mods 8 04-20-2004 10:04 PM
How high of the strings do u guys set? jolly Ibanez JEM, UV, JS & Other Signature Models 2 10-10-2003 03:36 PM
