Help with Ibanez ZR2 bridge tuning problem - Jemsite
post #1 of 5 (permalink) Old 09-15-2010, 01:26 PM Thread Starter
I bought an Ibanez S5470 Prestige a few months ago. It was strung with .09s, but I play in D standard so I put on some .10s. I have not been able to get the bridge to stay in tune perfectly since. It stayed in tune really well before I restrung it.
It is doing some really strange stuff, if I push the whammy bar down a fair distance, when it returns to its neutral position, it is really out of tune. However after doing this, if I pull the whammy bar up and hold it for a seconds, when it returns to the neutral position, it is in tune again. If i upbend it without doing a divebomb, it stays in tune too.
I have the spring tension adjusted so the bridge is parallel to the body, and I have tried removing the ZPS system. The strings are tightly locked at the locking nuts, and the things that hold the strings in place on the bridge.
Does anyone know what the problem might be? Thanks for any help!
Arycama is offline
post #2 of 5 (permalink) Old 09-15-2010, 02:59 PM
Reviews: 9
Re: Help with Ibanez ZR2 bridge tuning problem
I assume you adjusted the spring tension? How did you do that, did you use the roller that sticks out the cavity cover?
Fun111 is offline
post #3 of 5 (permalink) Old 09-16-2010, 01:18 AM Thread Starter
Yeah I adjusted it using the roller. The baseplate of the bridge is sitting parallel with the body.
Arycama is offline
post #4 of 5 (permalink) Old 09-16-2010, 04:28 AM
Reviews: 12
did you intonate the bridge when you changed strings?
Reg
reguv760 is offline
post #5 of 5 (permalink) Old 09-16-2010, 04:39 AM Thread Starter
Yeah I did.
Arycama is offline
bridge , floating , tuning , zr2
Ibanez AEG10EBK tuning problem mdmoyer Tech: Setup, Repairs and Mods 0 03-27-2009 08:38 PM
Tuning Problem geetarmonkey Tech: Setup, Repairs and Mods 5 12-28-2006 04:08 PM
Ibanez Rg350ex Tuning Problem Plz help iIbaneZz All Other Guitars (including Prestige) 9 01-17-2006 09:55 PM
tuning problem :( mikul Ibanez JEM, UV, JS & Other Signature Models 1 04-08-2005 08:28 AM
Help.. Tuning problem JBA.com Tech: Setup, Repairs and Mods 10 12-09-2002 05:27 PM
