Help: ID of this early 90īs model - Jemsite
post #1 of 6 (permalink) Old 01-23-2014, 01:10 PM Thread Starter
Hello, I need help identifying this model. It has an Edge and all the small switches of an early 540, but the larger dot fret marks and the "custom made" inlay make me believe its a later model. What year and exact model is this? Thanks!!
ebguitars is offline
post #2 of 6 (permalink) Old 01-23-2014, 04:40 PM
CosmicDebris's Avatar
Re: Help: ID of this early 90īs model
It is an S540 that has been modded. It should have came stock with a 5way switch and no mini toggles.
CosmicDebris is offline
post #3 of 6 (permalink) Old 01-23-2014, 04:51 PM
Its hard to tell with the little pics but are the set of three switches on a plastic riser piece? If so I would say its a later model that had the switches installed where the 5 way normally goes. If it were an early one the pickups would be the normal ibz/usa not the f2 c2 set, Also the 88's had the volume and tone closer together. If Im not mistaken the custom made logo started showing up in 90 so thats probably the best bet. What is the serial number on the neck plate?
edit:looks like while I was typing Cosmic beat me to it...but yeah. Should be a 90 or 91 most likely, I think they went to lo pros in 92.
Fastmerc is offline
post #4 of 6 (permalink) Old 01-24-2014, 03:57 AM Thread Starter
Thanks. This is the serial number: F024096.
So you believe that it is some sort of a hibrid and that it has been modified. That sucks, I thought it was stock...
post #5 of 6 (permalink) Old 01-24-2014, 08:28 AM
So that makes it a 90 model. Seems stock except for the mini switches vs a 5way and of course the two extra minis between the volume and tone knob.
Fastmerc is offline
post #6 of 6 (permalink) Old 01-24-2014, 10:37 AM Thread Starter
Ok, thanks again mate!
540 , ibanez
WTB Ibanez Prestige Hardcase and an early model Ibanez compressor. Dylmeistr Classified Ads: Guitars and Gear 2 11-01-2012 04:04 PM
WTB: Jackson Phil Collen Model from late 80's-Early 90's For_The_Love_Of_Jems Classified Ads: Guitars and Gear 13 10-24-2011 02:28 PM
WTS: Peavey 5150 120W Head Early Model Block Lettered $600 dirkdiggler Classified Ads: Guitars and Gear 2 06-17-2011 06:12 AM
FS:Ibanez RG550DY (MIJ) Early 90's Model MTM2-live Classified Ads: Guitars and Gear 12 07-13-2009 09:50 AM
Marshall 4x12 *cabinet - early 80's model...need info vwall Gear, Equipment, Recording & Off Topic 5 06-02-2001 09:40 AM
