Help with my Ibanez Edge Pro bridge? - Jemsite
post #1 of 12 (permalink) Old 09-21-2009, 09:26 AM Thread Starter
when i put my whammy bar in the edge pro bridge on my RG2570E-VSL, i press it down and hear the click (which im supposed to).. but when its in then the volume knob comes in the way and i cant rotate it fully!!
the volume knob comes in the way of the whammy bar!!! please tell me how to do this .. i am new with edge pro but i have used edge III before a lot. in the instruction manual of the prestige it says nowhere about adjusting the height of whammy bar, but i could do it in my old rg350 with the edge III bridge...
umairnadeem is offline
post #2 of 12 (permalink) Old 09-21-2009, 10:07 AM
Re: Help with my Ibanez Edge Pro bridge?
pull the volume pot and see if the shaft could be set lower. if you see some threatening off the washer, then it can be set lower. just add a washer below.
if the pot can't be set lower, i'd change the neck/body angle so that the trem would sit a bit higher (2mm is enough) without altering the action. or i would get a lower knob? or i'd try to bend the arm? you have several options...
nuno is offline
post #3 of 12 (permalink) Old 09-21-2009, 04:03 PM
Reviews: 15
I suspect your bridge angle is set wrong, i.e. angled too high. Can you post a pic?
MarkE is offline
post #4 of 12 (permalink) Old 09-21-2009, 04:19 PM
Reviews: 59
Pics would go a long way to help diagnose the problem.
smooth55 is offline
post #5 of 12 (permalink) Old 09-22-2009, 02:26 AM Thread Starter
actually its a bit too late now to post a pic.. because now i tigthened the springs a bit, and raised the action a bit... that fixed the problem but still the whammy is dead near close to hitting the knob again, but it doesn't make much of a problem anymore except for one:...
the problem remains that i needed to raise the action by A LOT. this never happened with any other floyd roses i had. the action is pretty high for a shredding standard.. i still want the lower action but i am looking for another way.. anyways ill post the new pic:
http://i1008.photobucket.com/albums/...olswhat002.jpg
http://i1008.photobucket.com/albums/...olswhat003.jpg
post #6 of 12 (permalink) Old 09-22-2009, 07:47 AM
Well first of all your volume and tone knobs are sitting way too high on the pots. They should nearly be touching the guitar. Second, the trem is set pretty low in the body. I can barely see the knife edge. If you had to raise it significantly to get to that point, then it must have been REALLY low before that.
My guess is that your real problem is the neck huge a huge amount of relief in it and someone dropped the trem way down to try to compensate for high action at the upper frets. Check your neck relief and I bet you'll find that you need to tighten down the truss rod to get it set properly. Also check the nut height, it's almost certainly too high as well. Once you get the neck setup correctly, you'll probably be able to raise the bridge and combined with getting the knobs mounted right, I think your problem should go away. Click on the Ibanez Rules banner at the top of the page and go to the tech section there is you want to see a good tutorial on setting up the guitar.
Takin' a Ride is offline
post #7 of 12 (permalink) Old 09-22-2009, 04:01 PM Thread Starter
but wait if the thing i want to do is raise the bridge and still have a low action, then won't i need the neck to curve upwards and therefore be loosening the truss rod? or do i need to tighten it for some reason??
post #8 of 12 (permalink) Old 09-23-2009, 03:49 AM
Originally Posted by umairnadeem View Post
...if the thing i want to do is raise the bridge and still have a low action, then won't i need the neck to curve upwards and therefore be loosening the truss rod?
nope, that case you want to change the neck/body angle by putting a shim onto the joint. a 0.5mm thick shim is enough.
(the schemes below are deliberately exaggerated for better comprehensibility)
upview
sideview
nuno is offline
post #9 of 12 (permalink) Old 09-23-2009, 04:35 AM
Reviews: 4
Yep. A credit card or some cardboard will do the trick.
SilverEra is offline
post #10 of 12 (permalink) Old 09-23-2009, 09:45 AM
Check your neck first, then look at shimming the neck if the trem is still too low.
post #11 of 12 (permalink) Old 09-23-2009, 01:13 PM
jb4674's Avatar
Reviews: 18
I'd say that's a bit excessive height wise, don't you think?
Jimmy
jb4674 is offline
post #12 of 12 (permalink) Old 09-24-2009, 05:55 AM
The Tone/volume knobs do look way too high, they need to be lowered.
GTR-MAN is offline
edge pro bridge help
new ibanez Edge Pro bridge or floyd lo pro bhuard75 Tech: Setup, Repairs and Mods 10 09-02-2010 10:51 AM
FS: Ibanez Lo Pro Edge 7 String Bridge - shred777 Classified Ads: Guitars and Gear 1 07-12-2007 12:02 PM
Question about the edge pro bridge on higher end Ibanez elpingua All Other Guitars (including Prestige) 3 11-19-2005 09:20 AM
WTB: Ibanez edge or low pro bridge IanRG7421XL Classified Ads: Guitars and Gear 1 07-26-2005 07:51 PM
WTB: Ibanez edge or low pro bridge IanRG7421XL Classified Ads: Guitars and Gear 0 07-26-2005 06:38 PM
