HELP! need neck specs on a RG1550M Prestige - Jemsite
post #1 of 4 (permalink) Old 01-31-2010, 06:57 PM Thread Starter
Exclamation HELP! need neck specs on a RG1550M Prestige
Got Ernie @ ET Guitars working on a custom neck for me and I need to get him the specs for the neck on my RG 1550M Prestige as a guideline. Have dug up so much freakin' data but none seems to pertain exactly to the 1550M. It's a Wizard Prestige neck but beyond that it's way too convoluted...
If anyone has the exact spec (widths, thicknesses, radii) PLEASE post them.
jsv555 is offline
post #2 of 4 (permalink) Old 01-31-2010, 07:04 PM
Reviews: 15
Re: HELP! need neck specs on a RG1550M Prestige
You should find the nut / 12th fret thickness, neck width and fretboard radius but to get a copy of the neck profile you're going to need to have your 1550M measured.
MarkE is offline
post #3 of 4 (permalink) Old 02-01-2010, 10:19 AM
pulled from GC site:
Ibanez RG1550M Electric Guitar Specifications:
* Neck dimensions:
* Scale length: 25.5", 648mm
* Width at nut: 1.69", 43mm
* Width last fret: 2.28", 58mm
* Thickness 1st fret: 0.70", 18mm
* Thickness 12th fret: 0.78", 20mm
* Radius: 16.92", 430mm
saijo is offline
post #4 of 4 (permalink) Old 03-02-2010, 08:16 PM
Reviews: 12
* Neck dimensions:
Ok got that info now could anyone tell me the size of the heel? I have heard that the Prestige necks are wider or at least bigger somehow in the heel and it will not fit in a non-Prestige pocket?
I am looking for another neck Like the 94 RG550 Wizard neck I have and I have not had much luck so I thought I may go to a prestige neck if I can get the specs and see if I can mod it to fit properly.
Are all prestige AANJ necks the same or do they change depending on what model # they are on?
spudler_t is offline
rg 1550m , specs , wizard prestige neck
Boutique built SG with PRESTIGE neck specs photios Classified Ads: Guitars and Gear 0 01-19-2010 10:02 AM
Ibanez Prestige RG1550M nitro All Other Guitars (including Prestige) 2 12-15-2009 02:24 PM
FS 2009 Ibanez Prestige RG1550M Phantom Blue gtobrett Classified Ads: Guitars and Gear 0 07-22-2009 02:35 PM
FS/FT: Ibanez RG1550M-PBL(Phantom Blue) Prestige. (New from 2009) GuitarEvan07 Classified Ads: Guitars and Gear 4 05-01-2009 10:40 PM
Need help w/ RGPR1 identification/ specs! Texas GC Prestige TLCguitars All Other Guitars (including Prestige) 22 01-01-2005 01:58 PM
