Help needed - Jemsite
post #1 of 8 (permalink) Old 06-11-2011, 08:55 AM Thread Starter
Help needed
Seems like the tension from the tremolo pulls left side insert post out from the body for about 1 cm, as you can see on the photos whenever i put a tremolo on the guitar and try to restring it.
doesnt seem like anything is wrong with the hole or the insert, still it cant hold it. right one you can not pull out with a real force. so whats different???
Toca is offline
post #2 of 8 (permalink) Old 06-11-2011, 09:14 AM
Re: Help needed
Sometimes inserts loosed up over time on old guitars. My suggestion would be to re-seat the insert and then use thin super glue to lock it back in place. Thin super glue will penetrate down around the sides of the insert and should create a good bond. I like this stuff:
http://www.stewmac.com/shop/Glues,_a...uper_Glue.html
Takin' a Ride is offline
post #3 of 8 (permalink) Old 06-11-2011, 09:38 AM Thread Starter
Re: Help needed
Thanks, didnt know it happens. all of my Ibanez guitars are 20+ , but never noticed it.
i got some of the JB Weldt stuff left. maybe it could do the job too,hm?
Toca is offline
post #4 of 8 (permalink) Old 06-11-2011, 10:26 AM
Ayrton's Avatar
Re: Help needed
Super Glue or even regular yellow wood glue will work just fine. I would not suggest JB weld.
Ayrton is offline
post #5 of 8 (permalink) Old 06-11-2011, 11:04 AM
RGTFanatic's Avatar
Re: Help needed
Takin' is right on the money again!!!!
Sometimes (especially if the locking screw is not tightened) the wood in front of the insert will soften from the tension put on it by the strings/springs. You can see how the paint is chipped off in front of the insert. This is the evidence that the wood has softened. The hole is now slightly ovaled (egg shaped).
Takin's super glue method is VERY effective if the amount of "oval" is very small. If it's very out of round (can't see the affected area in your first pic) another repair method will be needed. It's still a simple fix, just different.
Ayrton is also right.... DO NOT use JB weld. It will be impossibe to "fill" the affected area completely. You'll end up with a rock hard ball of JB weld at the top of the anchor that would then put even more tension on softened wood...... It WILL make the problem worse, not better.
RGTFanatic is offline
post #6 of 8 (permalink) Old 06-11-2011, 11:10 AM
RGTFanatic's Avatar
Re: Help needed
BTW Toca... is that an FGM100??? Awesome guitar man!!!
post #7 of 8 (permalink) Old 06-12-2011, 09:53 AM
Re: Help needed
Had the same problem on my RG. Wood glue did the trick for me.
sweepymctaptap is offline
post #8 of 8 (permalink) Old 06-12-2011, 12:05 PM
Re: Help needed
As others have said, either wood glue (most people recommend Original Titebond) of super glue should work. There are three reasons I recommended super glue:
1. You're bonding wood to metal. Wood glue is meant to bond wood to wood.
2. Wood glue is very thick and I question its effectiveness here. You'd have to coat the insert with a thin amount of glue and then hope that it squeezes out the top when you insert it. There's always a chance that glue gets trapped below the insert, which would make it impossible to seat completely.
3. Thin super glue has a natural tendency to wick into even the tiniest cracks, making it ideal for repairs like this.
When I work on guitars, I consider it basically standard practice to hit the edges of the neck pocket with super glue, either to fill existing pocket cracks or try and prevent them. I've also used it to fix some small stress cracks in a neck at the nut bolts and it worked great there as well.
edge , insert posts
help needed keitho Ibanez JEM, UV, JS & Other Signature Models 4 02-28-2010 05:54 PM
Help Needed. Passion_and_Warfare Off-topic / Miscellaneous 21 08-16-2007 08:50 AM
tab needed Hartfolk Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 0 12-03-2006 12:05 AM
RGR 570 ? Help needed on a buy Silverburst All Other Guitars (including Prestige) 16 10-14-2006 03:44 AM
Some help needed :( 7 Dying Trees Off-topic / Miscellaneous 10 10-06-2005 10:19 AM
