Help needed! - Jemsite
post #1 of 14 (permalink) Old 06-18-2006, 11:51 PM Thread Starter
Help needed!
Ok, the problem is this...
I have a RGR570FLB, as the model number suggests, it's a reverse headstock 570 in Blue Metal Flake. Anyway, I was thinking about adding some cool mods to it: Blue knobs, blue pickup covers and some blue DR strings. Well, I tried to remove the tone knob, thinking that just the Cosmo Black knob would come off. It seems that the knob is attatched to the stem and the whole thing came out and now I can't get it back in.
Does anyone know how to get them back in? And secondly, can they be modded with the blue plastic knobs?
Any help/input would be much appreciated.
Thanks.
RGR570 is offline
post #2 of 14 (permalink) Old 06-18-2006, 11:53 PM
Re: Help needed!
you mean the shaft came out with the knob..
if you do then you just got yourself a one way ticket to replacing the pot it was attached to..
You really got to be careful prying and pulling on knobs.
ibanezcollector is offline
post #3 of 14 (permalink) Old 06-18-2006, 11:59 PM Thread Starter
Re: Help needed!
Yeah, the shaft came out with the knob. I guess these knobs are welded to the shaft as there is no screw on the side of the knob. So, will I have to replace the pot itself?
RGR570 is offline
post #4 of 14 (permalink) Old 06-19-2006, 12:10 AM
Re: Help needed!
if the shaft came out with the knob you do..
you got to work them off.. I have a tutorial on projectguitar.com on how to do it with no damage
post #5 of 14 (permalink) Old 06-19-2006, 12:16 AM Thread Starter
Re: Help needed!
Ok dude, I'll check it out, thanks for your help, much appreciated.
RGR570 is offline
post #6 of 14 (permalink) Old 06-19-2006, 12:43 AM Thread Starter
Re: Help needed!
Ok, I have just tried removing the knob from the shaft and it seems like it's all one piece, are these knobs removable?
RGR570 is offline
post #7 of 14 (permalink) Old 06-19-2006, 02:28 AM
Gex
Re: Help needed!
Yup, your pot is history and needs replacing.
The knob, however, can be salvaged. They are not welded, glued, epoxied, cemented or anything to the shaft. It was just wedged in there real tight. Yes, they are indeed removable.
There are 2 main types of shafts and knobs that accompany them:
Look at this picture: A smooth shafted pot which requires a knob with a set screw:
And then there's the split shaft type. These are commonly used, and you can use both knobs with and without set screws. The split allows you to bend them slightly outward to make the knob fit on tighter (if it happens to slide off) and conversely. . if its too snug, you can get pliers and give them a little pinch and the sides should squeeze togeather a little. Thats how you get around the set screw, is you tailor the shaft to fit to the knob.
Ibanez Dome knobs are unique in that they dont require set screws like most dome style knobs. Dont give up on your knob just yet, you can always dremel/drill that old shaft out of there. That is. . unless a moron previous owner didn't understand that their pot just needed a little tweaking to make the knob fit and they went and glued the knob on.
Gex is offline
post #8 of 14 (permalink) Old 06-19-2006, 02:39 AM
Re: Help needed!
i always thought the cosmo knobs had a small allen screw attaching it to the post.
Ibateur is offline
post #9 of 14 (permalink) Old 06-19-2006, 03:36 AM
Re: Help needed!
my cosmo ones on my 570 do, but the black ones on my 560 don't.....how strange.....
jimmyfingersminion is offline
post #10 of 14 (permalink) Old 06-19-2006, 10:30 AM Thread Starter
Re: Help needed!
Thanks for the input guys, much appreciated.
RGR570 is offline
post #11 of 14 (permalink) Old 06-19-2006, 11:51 AM Thread Starter
Re: Help needed!
So, it seems that I'm gonna have to replace the tone pot.
I'm not sure if it should be 250k or 500k.
Could anyone point me in the direction of a suitable replacement?
Thanks in advance.
RGR570 is offline
post #12 of 14 (permalink) Old 06-19-2006, 07:41 PM
Gex
Re: Help needed!
Thanks in advance.
You'll need a 500K. One with a slotted shaft.
www.allparts.com
Gex is offline
post #13 of 14 (permalink) Old 06-19-2006, 11:00 PM Thread Starter
Re: Help needed!
Thanks for the help Gex, much appreciated.
RGR570 is offline
post #14 of 14 (permalink) Old 06-19-2006, 11:32 PM
Re: Help needed!
what they said +1,000
guitarslinger213 is offline
dome knobs , pickup cover , reverse headstock , style knobs
Peavey Classic 50/50. Help DESPERATELY needed. Yan7BSB Gear, Equipment, Recording & Off Topic 6 05-10-2006 04:35 PM
Info needed on RG2620 QM -URGENT- Jem7RB MK All Other Guitars (including Prestige) 1 12-07-2004 02:12 PM
Mesa Boogie Repair Needed - Your Opinions Wanted bpd111 Gear, Equipment, Recording & Off Topic 4 09-19-2003 10:14 AM
Advice needed on heavy distortion pedal Given to Fly Gear, Equipment, Recording & Off Topic 6 08-19-2003 11:19 PM
TRS/TRS II --> Edge/Lo-Pro Edge - no routings needed? cowcowcow Tech: Setup, Repairs and Mods 2 07-23-2001 02:31 PM
