help! rg350 strings popping out of saddles.. - Jemsite
post #1 of 2 (permalink) Old 04-30-2014, 11:28 PM Thread Starter
I've had my rg350 with the Edge II ZPS for a year now and I've changed the strings 3 or 4 times.
This latest time I have 2 or 3 strings that are popping out. I've got them locked in, Ernie Ball .10 gage and I'm thinking maybe the saddle T-joint things are either worn or the trem itself is worn on the connections? Its not rocket science to stick the string in and tighten the allen screw and I don't want to start stripping it.
I like the ZPS but the way Ibby handled the strings locking in the tremolo is a very poor design I think. I don't have any problems with my LoPro, Edge, or even the Edge III (not sure why so many hate that one) and like those designs cause they are easier to work with.
has this happened to anyone else? Can I file the connections? not sure what to do.
has anyone tried this:
"All Floyd style saddles suffer from strings popping out (especially the thin ones). There are some tricks you can do to prevent it. First of all, always make sure the string is sitting in the middle of the claw and not to the left or the right hand edge of the hole. Second, folding the end of the string back on itself until the tip is a 'U' shape helps. When you place this in the saddle the saddle block/claw is then making contact with twice as much material and giving more grip. Another trick is to fold the end of the string into an 'L' shape and slide the bottom of the 'L' under the claw/saddle block, if the block design allows for it. This allows the string to be pressed against two surfaces of the block, the vertical section of the 'L' against the front of the block, the horizontal section against the bottom of the block."
Thanks in advance!
windycitycane is offline
post #2 of 2 (permalink) Old 05-06-2014, 01:02 AM Thread Starter
Re: help! rg350 strings popping out of saddles..
just an update.. I re-strung the strings from the ball joint end and they are staying in the saddles. Basically, I found after some trial and error that the wound area near the ball joint is better suited for locking things in. I've played it a couple of times, staying in tune and the strings sound good.
zps string change
Strings keep popping out - NEED HELP! KingV911 Tech: Setup, Repairs and Mods 4 03-26-2011 08:35 PM
Springs and Strings--The Case of the Popping Spring Hooks Wynterbite Tech: Setup, Repairs and Mods 2 01-10-2009 02:41 PM
Strings wearing grooves in Edge/LoPro saddles CrossingStar Tech: Setup, Repairs and Mods 3 01-01-2007 06:36 PM
new strings popping out of lock box. W0MB13 Tech: Setup, Repairs and Mods 3 07-31-2006 01:40 AM
acks! strings popping left and right BZ Beetle Tech: Setup, Repairs and Mods 9 01-08-2003 03:34 PM
