High e string intonation very low - Jemsite
 1Likes
post #1 of 17 (permalink) Old 08-01-2020, 07:26 AM Thread Starter
Intonation very low on the high e string, furthermore, string action is also very low on that string.
Is the intonation problem a result of the low string action, it is also buzzing a lot?
Should I raise the bridge on the treble side. I have the original edge bridge. Its on a Genesis rg550
Addy is offline
post #2 of 17 (permalink) Old 08-02-2020, 05:42 AM Thread Starter
Correction, not low, but flat.
Intonation very flat on high e-string. Also the string action very low, so it buzzez on many frets on the e-string. Especially on the first 7 frets
What to do?
Addy is offline
post #3 of 17 (permalink) Old 08-02-2020, 05:54 AM
Re: High e string intonation very low
Fret buzz at that end of the neck suggests insufficient relief, but if it is only the high E that would be odd- twisted neck or a fret issue somewhere. What is your action like at the 12th fret?
Sort that before getting into the intonation. If fretted notes are flat you need to move the saddle towards the neck.
Algiman is offline
post #4 of 17 (permalink) Old 08-02-2020, 07:04 PM Thread Starter
About 1 mm on 12th fret high e string and almost 2 mm on low e string
It is very strange, I bought the guitar a few years back, and ended up not playing it. But I vaugely remember lowering the bridge slighly to get a lower string action. And I am 100% certain that I did not do anything with saddles. So how can intionation all of a sudden go without me changing the saddles?
Addy is offline
post #5 of 17 (permalink) Old 08-02-2020, 11:25 PM
1mm is very low, I suggest you raise it a little but these things are all personal preference. It is possible you have a dodgy or damaged string too. Try changing it.
Algiman is offline
post #6 of 17 (permalink) Old 08-03-2020, 04:30 AM
Definitely worth checking this..
I had a JS 1000 that buzzed only on the high e.
Drove me mad for ages. I got my fret rocker out, no high frets.. Raised the bridge. Still awful.
Was starting to get paranoid that my neck had a twist as the relief was fine everywhere else.
Turned out it was the way the string was resting in the locking part of the trem.
And as soon as I changed the string the issue just disappeared and never returned.
Algiman likes this.
ibaraki_gaijin is offline
post #7 of 17 (permalink) Old 08-03-2020, 02:35 PM Thread Starter
Yes I want to raise it, but for some strange reason, I can't find the correct allen wrench, what size should it be, you know?
Addy is offline
post #8 of 17 (permalink) Old 08-03-2020, 02:42 PM Thread Starter
Interesting!
Will change string if it doesn't work with raising the bridge. Just need to figure out correct allen wrench size
Addy is offline
post #9 of 17 (permalink) Old 08-03-2020, 03:32 PM
4mm, and a 1.5mm for the locking one inside (I think the genesis has them)
Algiman is offline
post #10 of 17 (permalink) Old 08-03-2020, 08:38 PM Thread Starter
I have the wrench for the inner lock, but the main 4mm I don't seem to have. Need to go and get one, will be back asap, and let you know how it is going. Thanks for your help so far.
Addy is offline
post #11 of 17 (permalink) Old 08-06-2020, 12:56 PM Thread Starter
Got a correct allen wrench, raised the bridge where action now is about 1,5 mm around 12th fret. If I raise it more action will be too high on the high frets.
However...
It is still buzzing all over the fretboard on the high e string and intonation is still way off on high e string
Very annoying.
I was going to loosen the neck a little, but notice it is not an allen wrench but seem to need something else?
Addy is offline
post #12 of 17 (permalink) Old 08-06-2020, 01:10 PM
By high e do you mean the unwound string? If so put pressure on the back half of the e and b saddles and see if it goes away.
Rich is online
post #13 of 17 (permalink) Old 08-07-2020, 03:36 PM Thread Starter
Yes unwounded string.
You mean just push down towards the guitar? I did push with my fingers on the e string saddle just to see, buzzing still there.
Also turned the neckscrew counter clockwise to add more relief to the neck, but still buzzing and flat note.
Addy is offline
post #14 of 17 (permalink) Old 08-07-2020, 09:15 PM
The back half of the saddle, not the front half where the string is locked in.
Rich is online
post #15 of 17 (permalink) Old Yesterday, 09:30 AM Thread Starter
Yes still buzzing
And now I added more relief to the neck so now the action on the unwounded high e string is closer to 2mm on 12th fret and still buzzing on fret 1 to 7.
Not nearly as bad as before, but still.
Addy is offline
