High E is too tight. - bending this string is a bugger - Jemsite
post #1 of 9 (permalink) Old 01-01-2002, 05:11 PM Thread Starter
Ok, here's the deal;
The high E on my guitar is much tighter and difficult to bend than on other guitars I've played.
The guitar has a floating trem (Floyd Rose) with a lock nut, of course. The headstock is like a Peavey Wolfgang's but on an angle.
Here are some of the things I've looked over:
- I've adjusted the intonation saddles
- Adjusted the action
- Re-positioned the trem springs (straigh across like this http://jemsite.com/tech/img/t_spr1.jpg)
- leveled the trem
- Made sure nothing was in the way of the string on the saddle and lock nut.
The string gauge is .010 but I doubt that's the problem. I've used .008s and .009s in the past and it's had the same problem.
Anyone?
Vai the god of Sound is offline
post #2 of 9 (permalink) Old 01-01-2002, 05:25 PM
just guessing, but maybe one of the springs is too tight? How many are there?
what's the scale?
yurich is offline
post #3 of 9 (permalink) Old 01-01-2002, 09:15 PM Thread Starter
scale is 25.5 I believe (22 frets) and there are 3 springs.
post #4 of 9 (permalink) Old 01-01-2002, 09:19 PM
all along the board? may be a rough fret....
caprile is offline
post #5 of 9 (permalink) Old 01-01-2002, 10:18 PM Thread Starter
Yeah, it's across the whole board. I do have a few dead frets that need a re-dressing, possibly be replaced, but it would affect all the strings if that was the case.
post #6 of 9 (permalink) Old 01-08-2002, 07:21 PM
Heres a couple of thoughts..
The action / *tremolo angle mayneed adjusting....this causes perceived greater string tension.....
Keep the action to about 1.8- 2.0mm at the 24th fret
make sure the temolo angle is not too high....see the tech section
10s dont help...try a mixed set of heavy gauges for the E A D and lighter for the G B E
hope this helps
Scott
toneseeker is offline
post #7 of 9 (permalink) Old 01-08-2002, 07:23 PM
almost forgot
give the neck and frets a good cleaning.....rich's site has superb info on that *
good
luck
post #8 of 9 (permalink) Old 01-13-2002, 03:45 PM Thread Starter
I've actually play a jem with .010s and they were still pretty loose.
post #9 of 9 (permalink) Old 01-14-2002, 07:15 AM
If you are finding the strings hard to bend it may be because the springs are still very stiff. The more abuse they get, the more they'll loosen and the easier it will be to bend. Basically, when you bend a string you are pulling the tremelo towards you, ie fighting against the pull of the strings. The stiffer the springs are, the harder it will be to bend basically. Maybe it'll get better when they are worn in?
7 Dying Trees is offline
floyd rose , lock nut , peavey wolfgang , string tension , trem springs , tremolo angle
Guitar String Bending Problem Ibzplayer Tech: Setup, Repairs and Mods 9 11-08-2011 12:37 PM
Bending on high scalloped frets. Timothong Ibanez JEM, UV, JS & Other Signature Models 3 08-08-2009 08:06 PM
Sting changes tone when bending another string. Ibanezboy1 Ibanez JEM, UV, JS & Other Signature Models 3 02-15-2009 11:12 AM
String bending (low action) blackpuppets Tech: Setup, Repairs and Mods 12 10-27-2005 02:56 PM
High E string goes flat after bending eg Tech: Setup, Repairs and Mods 6 11-25-2004 05:35 PM
