how to darken a light rosewood fretboard on my rga121? - Jemsite
post #1 of 26 (permalink) Old 03-05-2007, 08:39 PM Thread Starter
Hey, guys. I got my new rga121 today... body looks great, guitar plays great... I like everything about it, except the rosewood fretboard is very, very light colored.. it came from las vegas, nevada.... so, I'm guessing it got pretty dried out there, I'm going to get some kind of lemon oil or fretboard conditioner for it to get some moisture back in the wood, but I don't think that's going to darken it up how I want. honestly, the fretboard looks pretty ugly right now.... so, what should I do? I read about two things people suggested: Watco Danish Oil wood stain/finish that a few luthiers said they used & Fiebings oil stain dye for fretboards from stewmac.com.... have any of you ever done this before? any suggestions?
Thanks,
Josh
JoshuaLogan is offline
post #2 of 26 (permalink) Old 03-05-2007, 08:50 PM
Ayrton's Avatar
Re: how to darken a light rosewood fretboard on my rga121?
Old English scratch remover is what I use. Follow that up with some Fret Doctor.
Ayrton is offline
post #3 of 26 (permalink) Old 03-05-2007, 08:53 PM
Quite a few people use the Fiebings oils dye (it's actually leather dye)with good results.
Most people use it to give the effect of an ebony fretboard.It doesn't really look like ebony up close because the grain structure of rosewood is much more open but it darkens it up a treat.
JTM45 is offline
post #4 of 26 (permalink) Old 03-05-2007, 08:54 PM Thread Starter
is it just conditioner or will it significantly stain the wood a darker color too? this thing is REALLY light
post #5 of 26 (permalink) Old 03-05-2007, 08:58 PM
Ayrton's Avatar
It is stain, so be mindful what you get it on. I use a Q Tip and just rub between the frets. The more costs, the darker it gets.
Ayrton is offline
post #6 of 26 (permalink) Old 03-05-2007, 09:06 PM Thread Starter
thanks, guys. one more question. will these stains cover the inlays too? I actually wouldn't mind if they do (I like the look of fretboards without inlays), but I'm just curious
post #7 of 26 (permalink) Old 03-05-2007, 09:15 PM
Ayrton's Avatar
Most inlays are plastic and when you apply this, it is wipe on the wipe off. I don't let sit for more than a minute or so, before I wipe down the board with a clean cloth. Scratch remover is a mild stain, so it should not affect the plastic inlays.
Ayrton is offline
post #8 of 26 (permalink) Old 03-06-2007, 05:11 PM
stratoskier's Avatar
Stew Mac sells a product called "Black Fingerboard Stain" that people have used to darken rosewood boards. No telling if it's really any better than the more common products mentioned by other posters, though.
Bert
stratoskier is offline
post #9 of 26 (permalink) Old 03-10-2007, 02:44 PM
Dont even waste your time with those other dyes and such, just use some Lemon Oil, it will moisturize your fretboard as well as darken it up a good bit. I actually had the same problem with my RGA121TKF when i first got it, the lemon oil did wonders!
clnh5 is offline
post #10 of 26 (permalink) Old 03-10-2007, 03:01 PM Thread Starter
Thanks, guys. I did a little research and found out that bore oil is about the best thing you can use on the wood. and the only real options I found were Fret Doctor and Roche Thomas Fretboard Oil. I got the Roche Thomas stuff since it was cheap and supposed to be very good.. even recommended by guys like John Suhr
I think it's going to work well, because I've noticed over the last week that spots on the fretboard have slightly been darkening where I've been playing a lot... I'm guessing some oil on my fingertips got into the board a bit... so if I am seeing a difference from that, I bet the bore oil will work really well... should be here monday I think
post #11 of 26 (permalink) Old 03-12-2007, 12:02 AM
Ayrton's Avatar
Here is the best example of what scratch remover will do for light or bland rosewood. I follow this up with some bore oil or similar.
My brand spankin' new Les Paul.
Ayrton is offline
post #12 of 26 (permalink) Old 03-12-2007, 12:08 AM
Dee
Fret Doctor is GREAT stuff. Give it a try sometime. BTW, not to be an ass, but these oils don't "darken" the wood, they merely restore the original colour. A light board is just dry, basically.
Dee is offline
post #13 of 26 (permalink) Old 03-12-2007, 12:43 AM
that looks a lot better imo , i usually keep my rosewood boards soaked in lemon oil but i think i may try that .
j.arledge is offline
post #14 of 26 (permalink) Old 03-12-2007, 01:17 AM
Ayrton's Avatar
I want to point out that the scratch stain is not a replacement for lemon oil or any other conditioner. I just use it to darken the wood, then use conditioner.
http://www.beafifer.com/boredoctor.htm
Ayrton is offline
post #15 of 26 (permalink) Old 03-12-2007, 12:27 PM
GAZ
Exclamation Re: how to darken a light rosewood fretboard on my rga121?
Rosewood (which can be several different species of tree) does vary a lot in colour and grain, especially on Ibanez guitars for some reason. A word of warning, use fingerboard oils sparingly and only when necessary, Over use will result in slight loss of tone and sustain, and you'll end up with a fingerboard that gets 'cruddy' very quickly ! The wood will only absorb a tiny amount, any excess should be removed completely.If the wood is still light after an application of lemon oil or equivalent, the only option to permanently darken it is a wood dye/stain, which I know Fender have used in the past to get their 'very red' rosewood fingerboards. Personally I'd live with it.
GAZ is offline
ebony fretboard , ibanez guitars , john suhr , jumbo frets , les paul , rosewood board , rosewood boards , rosewood fingerboard , rosewood fretboard , wound strings
Maple fretboard vs Rosewood john1880 Tech: Setup, Repairs and Mods 21 10-01-2005 09:19 PM
Darkening the color of a rosewood fretboard Drache713 Tech: Setup, Repairs and Mods 17 01-19-2003 08:18 AM
UV777BK neck... - Dark or Light rosewood? armdias Ibanez JEM, UV, JS & Other Signature Models 3 01-29-2002 05:14 PM
Universe Rosewood Fretboard - Why are some so close to black seven7seven Ibanez JEM, UV, JS & Other Signature Models 9 10-01-2001 07:51 PM
Looks are every thing. - Light rosewood looks bad jem7pbk Comments to Ibanez 8 03-25-2001 12:28 AM
