How to decrease natural tone settings on PGM guitars? - Jemsite
post #1 of 7 (permalink) Old 05-14-2011, 10:55 AM Thread Starter
Hello everyone,
So I am a more classically trained guitarist who took a forray into electric guitars a few years ago, but I am still weak on the tech side of things. As you all may or may not know, the PGM series lacks a tone knob. My question is, is there anything that I could do to soften up the tone? Thank you.
Also, is this the correct thread, or should I put this in the Tech section?
Sincerely,
Jon
bobombom is offline
post #2 of 7 (permalink) Old 05-14-2011, 12:49 PM
Re: How to decrease natural tone settings on PGM guitars?
Greetings.
A couple of thoughts off the cuff here:
If there's a treble-bleed cap on the volume knob in the stock wiring, you could remove that. The result is that, when lowering the volume, even very slightly, there's a disproportionately larger drop in audible higher frequencies (the very thing the bleed cap is meant to prevent, of course).
That way, a very slight 'crack' in your volume setting will yield a 'mellower' sound right off the bat.
Another possibility, a bit more advanced; you could replace the volume with a stacked concentric pot, wherein one part is wired as the volume, and the other, a tone control. No new holes in the guitar, and a fully reversible modification.
Let me know if either of those fits the bill.
Cheers.
steve is offline
post #3 of 7 (permalink) Old 05-14-2011, 01:06 PM
Reviews: 98
Your best solution in the EQ on your amp. If you can't dial in what you're looking for there, the next step is adding an EQ pedal to the chain.
AlaskaBat is offline
post #4 of 7 (permalink) Old 05-14-2011, 01:58 PM
Cheers.
+1 did that with a MII. Works fine
dragsternj is offline
post #5 of 7 (permalink) Old 05-14-2011, 09:35 PM
When I first began playing, I was not able to figure out why my clean sound was just not to my liking, I found that just by lowering the volume helps alot.
X2 on the Concentric knob, and or the EQ pedal. One or the other may do the trick. and You never know If you do both, you're tone could be what your looking for or better. But dont forget it could be vise versa and not be close.
My thought is: You have to experiment. Its the only way through trial and error to get a sound you are looking for. It can get expensive, please note.
Robbles is offline
post #6 of 7 (permalink) Old 05-14-2011, 09:42 PM
Reviews: 120
The other option would be to replace the 500K volume pot with a lower value one, 300 or 250K might do the job?
Or does that only work for tone pots?
LonePhantom is online
post #7 of 7 (permalink) Old 05-16-2011, 07:45 PM
Lower value volume pot would definitely bleed off a bit of top end, as well, so that's a good option as well.
steve is offline
effects , paul gilbert
decrease in output and sound asolid Tech: Setup, Repairs and Mods 7 09-09-2010 05:53 PM
JSX Clean Channel settings - Joe's settings? Toadfish Gear, Equipment, Recording & Off Topic 6 02-11-2009 05:25 AM
Why did Ibanez decrease high-end guitar models? no1spretty All Other Guitars (including Prestige) 20 08-11-2006 03:17 PM
Settings for good tone from Gibson SG and Marshall TSL601!!! Kroeger Gear, Equipment, Recording & Off Topic 5 08-11-2004 04:31 PM
Please make some natural colored/oiled finish guitars!!! hyesac Comments to Ibanez 5 01-06-2003 04:19 AM
