How do I identify RG without its neck...? - Jemsite
post #1 of 8 (permalink) Old 02-26-2018, 10:18 AM Thread Starter
I have what I think is an RG360DX 10+ years old, but can't remember why I think that other than trawling through the ibanez.wikia site and going off looks
Thing is, I can't check the serial number on the neck because it has been replaced with an unbranded one.
So if i said it's
Black
HSH (uncovered, no logos)
No pickguard
No model name on the bridge
Black hardware
Pickup mounts
By my reckoning it could be an RG270, 370, Gio, perhaps a number of others.
Any ideas what else I could look for to help identify it?
And a supplementary question - if it is bottom of the line, would the same body be used on superior models with "superior" just meaning hardware? i.e. I see the 570, 870, and indeed some PGMs and JPMs, also have basswood bodies.
Thx,
Andrew
Zerozeddy is offline
post #2 of 8 (permalink) Old 02-26-2018, 10:42 AM
site founder 0% owner
jemsite's Avatar
Re: How do I identify RG without its neck...?
AANJ or square heel? identify then search by Ibanez tremolo first as it makes it much easier to limit your Ibanez search. The body should have an identifier in the heel though.
jemsite is offline
post #3 of 8 (permalink) Old 02-26-2018, 10:52 AM
Can you provide a picture of tremolo? That usually helps narrow down the price level of the axe.
Any text on the pickups?
How does the input jack look (routed whole, or plate)?
And to answer your questions - there are slight differences between higher end and lower end RG bodies - different routing for different trems, direct mounted pickups vs ring mounted, different input jack route. Probably few others. I can imagine, that maybe there's also some wood selection process for higher-end models.
mlusiak is offline
post #4 of 8 (permalink) Old 02-26-2018, 11:26 AM Thread Starter
Thanks, chaps, will do some pics. Although it'll just be a case of finding out whether it's a cheap guitar or a really cheap guitar...
(I can't get a pleasing sound out of it (I'm assuming they are Powersounds), but I don't know at what point a whole new instrument is better than just swapping the pickups, for example. The fab neck that's on it is a custom-built LED thing, so if I got a better carcase (I'd prefer a hardtail) I'd have to get the router out, which I don't fancy. Or not use the LEDs I guess.)
This is the thing that's confusing me. It seems that someone put a 750 neck on a 250 guitar.
post #5 of 8 (permalink) Old 03-01-2018, 10:53 AM Thread Starter
Pic of bridge attached.
Going off a black finish with black hardware, I've narrowed it down to RG270, equivalent Gio GRG270, RG470 (long shot) and RG370DX.
post #6 of 8 (permalink) Old 03-01-2018, 11:08 AM
This is EdgePro II that was mounted primarily on RG3xx series guitars, so it's most likely RG370DX or RG370B. RG270 had different trem and chrome hardware I think.
I have the RG370B, it was my first Ibanez. The trem is not awesome, but it's not horrible either. It keeps tuning fairly well, but the way whammy bar is locked is very rubbish.
EDIT: And yeah, pickups on those were Powersounds and later INFs. Those look like Powersounds - not very good pickups in my opinion.
mlusiak is offline
post #7 of 8 (permalink) Old 03-01-2018, 11:15 AM Thread Starter
Great, thanks!
post #8 of 8 (permalink) Old 03-05-2018, 06:22 AM Thread Starter
Duh. Just in case anyone is looking at this thread to identify their instrument, when I opened up the back to faff with pickups and soldering I found a sticker explicitly marking it as a RG370DX. Still, it was quite fun looking into it by more -er- roundabout methods...
basswood , body , identifying , rg270 , rg370
Please, Help Identify this RG! g.macdonnell All Other Guitars (including Prestige) 5 11-09-2014 11:13 PM
can someone help identify my rg? hippie76 All Other Guitars (including Prestige) 3 01-25-2013 01:56 AM
Help Identify this Square Heel RG Neck kigorri All Other Guitars (including Prestige) 6 01-20-2010 05:12 PM
Please help identify this RG supadupaguita All Other Guitars (including Prestige) 12 08-06-2008 12:16 AM
Please HELP to identify this RG Ibanezer All Other Guitars (including Prestige) 1 03-27-2004 06:04 AM
