How to get trem bar to stay in place? - Jemsite
post #1 of 11 (permalink) Old 05-17-2005, 06:04 PM Thread Starter
how can i keep my trem bar on my RG570 with an edge to stay in 1 spot, it keeps sliding down and when i try to get it back up i always hit the volume knob. Is there a way to secure it in place?
ElectriK is offline
post #2 of 11 (permalink) Old 05-17-2005, 06:22 PM
Re: How to get trem bar to stay in place?
http://www.jemsite.com/tech/t_3other.htm#tremarmrot
Andelusion is offline
post #3 of 11 (permalink) Old 05-17-2005, 06:30 PM Thread Starter
is there a way without using nail polish?
ElectriK is offline
post #4 of 11 (permalink) Old 05-17-2005, 06:47 PM
Wrap something like sticky tape around it.
What's wrong with using nail polish? It works well!
post #5 of 11 (permalink) Old 05-17-2005, 06:58 PM Thread Starter
i dont have any lol. and if i put nail polish, would it make it so that i coulnt remove the bar if i pulled on it?
ElectriK is offline
post #6 of 11 (permalink) Old 05-18-2005, 12:26 PM
you put it under the nylon washers not on top of them, so jeah, you will still be able to remove the trembar, yet it might be a bit harder then before (that's actually what you wanted)
evil_k666 is offline
post #7 of 11 (permalink) Old 05-18-2005, 03:16 PM
I've found that nail polish (my wife's by the way!!!) doesn't last very long
PTFE tape works ok, but new bushes or tightening the nut from inside the trem cavity is best.
As usual for any tech issues check out ibanezrules.com !!!!!!!!!!
markg5150 is offline
post #8 of 11 (permalink) Old 05-18-2005, 04:24 PM
do the trem arm mod if its possible. use the floyd trem in the edge.
1wi11 is offline
post #9 of 11 (permalink) Old 05-19-2005, 12:25 AM
i'm using nail polish and it works best for me...
so far in 2 years i put on 2 coats... this way i save money and get the same results without any mod or tightening the nut .....
post #10 of 11 (permalink) Old 05-19-2005, 12:48 AM
Nail polish wears off. There's another trick that I use: If you have any ziploc bags or D'Addario string pouches, cut a circle about the size of a quarter. Pull the bar out. Center the plastic over the bar holder and insert the bar into the plastic. It goes in tough, but it won't go anywhere.
rory is offline
post #11 of 11 (permalink) Old 05-19-2005, 01:44 PM
Nail polish was OK with me but lately I do what rory does. I cut out circles from plastic grocery bags (really thin ones) & lay that over the trem bar hole before the trem is in, then push the bar into the hole along with the plastic. It pretty much works only one time because it shreds the plastic up. So I just make a bunch of these little plastic circles at once.
CrossingStar is offline
floyd trem , trem arm
Trem arm wont stay in place. miniche All Other Guitars (including Prestige) 7 03-24-2013 03:16 PM
Picup selector won't stay in place mag8 Ibanez JEM, UV, JS & Other Signature Models 7 03-03-2011 05:53 AM
HELP- trem arm on new RG2550E wont stay stationary Noopz Tech: Setup, Repairs and Mods 4 01-15-2008 12:32 PM
Can't get arm to stay, tightened trem holder and everything... kalashnikov Tech: Setup, Repairs and Mods 5 10-09-2007 11:40 PM
How can i make the lo pro edge trem stay in tune? kalashnikov All Other Guitars (including Prestige) 32 02-01-2006 05:27 AM
