How hard is it to put DiMarzio pickups into a Carvin guitar? - Jemsite
post #1 of 7 (permalink) Old 08-27-2004, 06:58 PM Thread Starter
I heard some routing is needed to fit DiMarzio pickups into a Carvin guitar. Is this true? How much routing is needed and where?
microdmitry is offline
post #2 of 7 (permalink) Old 08-27-2004, 08:37 PM
Body mount pickups on rear routed Carvins with need to have about 3/16" routed in the existing hole,,just opens it up and gives a little wiggle room. But yeah,,,, routing would have to occure. I suggest a luthier.
~A
Allen Garrow is offline
post #3 of 7 (permalink) Old 08-27-2004, 10:29 PM
Re: How hard is it to put DiMarzio pickups into a Carvin gui
Couldnt you just reshape the pickups? Ive had to do this before it would seem easier than messing with the body routing and this way you could more easily revert back to spec when selling the guitar
sniperfrommars1 is offline
post #4 of 7 (permalink) Old 08-28-2004, 12:24 AM Thread Starter
Is it just for body (as in "direct to wood") mounted pickups, or for pickup ring mounted too? Also, how about just reshaping the pickup like Sniperfrommars suggested? Is this possible?
post #5 of 7 (permalink) Old 08-28-2004, 12:42 AM
I have done it before on other guitar designs using a dremel to file the shape of the pickup mounting plate down. I assume this will only apply to direct to wood mounted guitars though so if you have one with rings around the pickups then your likely good to go,
post #6 of 7 (permalink) Old 08-28-2004, 12:47 PM
I posed that exact same question to carvin and Dimarzio. They both "Cringed" when I mentioned dremel to the pickups. Obviously your call. Wouldn't suggest it. Route the body out, and and seal the wood with black non conductive paint and your up running.
~A
post #7 of 7 (permalink) Old 09-02-2004, 03:45 AM
Reference:
If ya have any questions, lemme know.
Cor
http://www.jemsite.com/phpbb/viewtopic.php?t=33158
Uncle Os is offline
dimarzio pickup , dimarzio pickups , mount pickups , mounted pickups , pickup ring
Dimarzio and Carvin Pickups for sale! aizenx Classified Ads: Guitars and Gear 1 03-04-2013 05:49 PM
Pickups up for sale - Dimarzio, Carvin aizenx Classified Ads: Guitars and Gear 0 02-26-2013 12:43 PM
FS/FT Dimarzio Pickups 6 & 7, Pedals, Guitar sebastian Classified Ads: Guitars and Gear 14 10-26-2011 08:35 PM
Carvin DC127, w. your choice of DiMarzio Pickups microdmitry Classified Ads: Guitars and Gear 5 08-03-2006 01:42 AM
Wayne Guitar-Green Meanie-Which Dimarzio Pickups are in it? tritheory All Other Guitars (including Prestige) 3 10-03-2005 12:15 AM
