How thick is the maple? - Jemsite
post #1 of 9 (permalink) Old 09-12-2001, 01:47 PM Thread Starter
How thick is the maple top on thr USRG30?
Thanx alot,
Ron
ronsws6 is offline
post #2 of 9 (permalink) Old 09-12-2001, 06:51 PM
7 mm
J>:thumbsup:
Vaibanez is offline
post #3 of 9 (permalink) Old 09-12-2001, 06:54 PM Thread Starter
Thanks!
ronsws6 is offline
post #4 of 9 (permalink) Old 09-13-2001, 06:14 AM
I own two usrg30s and the tops on both seem to be very thin and really just a venear. Much thinner than the top on my rg-1880 which is only a 4mm top.
7mm isn't that more like a exotic wood.
winterlong is offline
post #5 of 9 (permalink) Old 09-15-2001, 02:46 PM Thread Starter
Now I'm confused again. I can get my hands on one that I'd have to re-finish, but if it's just a veneer I'd be afraid of sanding through it. Who know's absolutely for sure?
Thanx
Ron
ronsws6 is offline
post #6 of 9 (permalink) Old 09-16-2001, 04:49 AM
I've sanded down ibanezs before with out going through the veneer(s540fm). and the top on my usrg30s is rather thick for a veneer, but to thin still for my call it anything else. as long as you hand sand it you should be fine.
Gary
post #7 of 9 (permalink) Old 09-16-2001, 08:44 AM
The UCEW tops are 1/2" thick. The tops on the USRGs are a 7mm veneer top. The reason they look thinner is because of the rounded edges od the body. It plays tricks on the eyes. Best way to tell is to look at it from the neck joint pocket or the trem cavity. No round off there.
J>:thumbsup:
Vaibanez is offline
post #8 of 9 (permalink) Old 09-16-2001, 11:23 AM Thread Starter
Thanx so much for the replies.
Ron
ronsws6 is offline
post #9 of 9 (permalink) Old 12-10-2001, 05:01 AM
gitarrero's Avatar
Here's a side shot of my 1991 UCEW:
Hope that helps,
Oliver
gitarrero is offline
neck joint
How thick is the JEM? SadClown12 Ibanez JEM, UV, JS & Other Signature Models 0 01-25-2010 07:52 PM
RG with a thick neck The Rossness All Other Guitars (including Prestige) 6 12-15-2009 05:30 PM
RGA121HCDR crushed ruby red have thick maple top? mozfan98 All Other Guitars (including Prestige) 2 02-03-2009 10:49 PM
How thick is an RGA? C.Thep All Other Guitars (including Prestige) 5 10-25-2006 08:59 PM
RG7 Sounds Not So Thick... THE UNIVERSAL ONE All Other Guitars (including Prestige) 19 09-29-2002 01:26 PM
