Humbucker Losing output ? - Jemsite
post #1 of 4 (permalink) Old 12-30-2008, 02:44 PM Thread Starter
I have recently bought bought a new Ibanez Guitar and have swapped the pickups around a bit. I ordered a ToneZone and an Air norton. I found the TZ too hot and thick in the bridge of the guitar (mahogany body, neck through), so I put a FRED in in the bridge that I have been using in my frankenstrat for about 10 years. The FRED has a output spec of 305 (mW I guess) and the AN has a spec of 275. However.... The AN seems a LOT louder than the FRED. For balance I have the AN almost flush with the top and the FRED is about as close as I dare get to the strings.
My Question:
Do humbuckers lose magnetic strength due to the magnet arrangement or did DiM make the FRED differentll years ago ? Or something else.
The FRED is iold enoug that the DP number is stamped into the baseplate of the pup, so I dont think it is a memory issue.....
Tanx
Scott
scotteggshell is offline
post #2 of 4 (permalink) Old 12-30-2008, 03:16 PM
Reviews: 12
Re: Humbucker Losing output ?
try lowering the screw poles on the AN and increasing the poles on the Fred.
Reg
reguv760 is offline
post #3 of 4 (permalink) Old 12-30-2008, 03:25 PM Thread Starter
I dont really have a problem with the setup, just puzzled by the fact that according to Di
M , the output of the FRED should be higher than the AN...
post #4 of 4 (permalink) Old 12-30-2008, 04:21 PM
Reviews: 12
mmm... double check the wiring on the Fred. If it's not that, maybe it IS an old pup that's losing it's strength but i've never heard of magnets losing their charm...
How is the AN orientated; is the screw poles towards the neck or bridge?
Also, shouldn't this thread be in the Pickups & Wiring section?
Reg
reguv760 is offline
Ibanez Losing Fans Thrash All Other Guitars (including Prestige) 68 01-28-2007 12:43 AM
Vintage Output Neck Humbucker TonyT1000 Pickups & wiring 3 07-04-2006 01:14 PM
Losing a loved one shredmaster Off-topic / Miscellaneous 26 06-06-2006 04:30 PM
How much output????? ELicari All Other Guitars (including Prestige) 3 07-05-2005 07:45 PM
Help with Evo Humbucker output Volumes!!!!!!! robbiedp Tech: Setup, Repairs and Mods 2 03-25-2005 01:02 PM
