I dropped my 1077 a minute ago... :( - Jemsite
post #1 of 12 (permalink) Old 11-27-2003, 04:24 PM Thread Starter
403
...from waist high, it was hung around my neck, the strap unhooked from the left hook and the axe slammed into the wooden floor back first and then turned on the string side from the impact !!!
the guitar has of course detuned a significant amount.
visually everything seems fine (apart from a tiny scratch around the floating bridge) but how can I check whether something is broken inside the neck or somewhere else???
403 is offline
post #2 of 12 (permalink) Old 11-27-2003, 05:26 PM
there's nothing to break inside the neck, a fall won't hurt anything inside usually. Basically if it looks ok, and still plays and works fine it is fine. Acoustics are another story, braces can pop, end blocks etc, but electrics are pretty resiliant. If there isn't any visible damage I'd say you're perfectly fine.
littlegreenman is offline
post #3 of 12 (permalink) Old 11-27-2003, 05:59 PM Thread Starter
403
phew
I think just before it hit the floor, the expression "my whole life flashed before my eyes" wasn't that far off
keep my fingers crossed but nevertheless phew again
403 is offline
post #4 of 12 (permalink) Old 11-27-2003, 07:19 PM
If it went flat, I would look at the trem posts, and make sure the wood didn't split where they are seated. I had a Universe do that, and with the extra tension, I am paranoid about it with my 1077's...lol
Akhenaten is offline
post #5 of 12 (permalink) Old 11-27-2003, 09:55 PM
I had the strap pin rip out of my RG7 at a gig the very first time I played it out. Luckily I caught it in time before it went splat, cos it fell neck first.
Petie is offline
post #6 of 12 (permalink) Old 11-27-2003, 10:35 PM
I think we should start a program to take battered and abused guitars and give them to better homes (i.e. me) Just kidding...mostly
Two hands31 is offline
post #7 of 12 (permalink) Old 11-27-2003, 10:53 PM
oh the joy of well seated dimarzio cliplock straps :> Never leave home without em :> I usually use the original screws with my cliplock straps they can usually be forced through the brass bushing with a little work.
sniperfrommars1 is offline
post #8 of 12 (permalink) Old 11-27-2003, 11:15 PM
I use the dimarzio screws but i take some string and jam it into the old screw hole then screw em in. its an old old woodworking trick for stripped screw holes, works like a charm.
Dead Roman is offline
post #9 of 12 (permalink) Old 11-27-2003, 11:31 PM
I just repaired mine with some glue and a matchstick *LOL* It was a cliplock strap but that didn't help since it was the screw that ripped out, not the strap itself.
Petie is offline
post #10 of 12 (permalink) Old 11-28-2003, 04:41 AM Thread Starter
403
will do
to all of you talking about straplocks (or whatever it's called), how much is a straplock system?
403 is offline
post #11 of 12 (permalink) Old 11-28-2003, 08:06 AM
will do
And what brand would you recommend?
post #12 of 12 (permalink) Old 11-28-2003, 11:27 PM
I use a variety of strap locks...i've broken them all, including the Dimarzio things. Those work well, I will admit, but i like my recessed Dunlops. Except on V's where the back of the neck one might release when it pushed against ya'.
That's just me...
cliplock strap , cliplock straps , dimarzio cliplock , dimarzio cliplock strap , dimarzio cliplock straps , strap lock , strap locks
May I have your attention for 1 minute! 6fingers Off-topic / Miscellaneous 0 11-23-2010 08:44 AM
1077 or 2077 ? Agent540 All Other Guitars (including Prestige) 11 03-11-2010 04:31 PM
Haha, men and last minute Valentine.... Darin Off-topic / Miscellaneous 41 02-15-2008 12:29 AM
Incubus' 22 Minute Odyssey Two hands31 Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 10 11-16-2004 06:00 PM
RG 1077 XL QUESTION buz1701 All Other Guitars (including Prestige) 1 01-19-2004 02:07 PM
