I need SERIOUS HELP!!!! Please?! - Jemsite
post #1 of 13 (permalink) Old 02-21-2007, 02:59 AM Thread Starter
I have been trying to wire up some new EMG's in my 93 ex1700(oddball model I know) the problems I am running into is well.....
1st, the configuration is hum, sin, hum. Problem there is: I am installing the ZW series(emg81 and emg85 humbuckers) I am leaving the OEM single in (temporary of course) and I cannot find a diagram close enough to explain the wiring/connections
2nd, I had to purchase a new 5-way switch (obviously scince ibanez is notorious for premature failure with their switches) I tried to contact manf. as did 6 other dealers where I live with no avail.(this is the only thing I do not like about Ibanez) So the best tech I know (has been repairing Ibanez for 15yrs, and is 1 of only 5 in my state qualified to build Ibanez guitars among others, So I figured his advice was relevent.) suggested a Fender 5-way, I am not big on mixing parts, but he assured me that it would work! (he is out of the country for the next month or I would have just gone to him, and as you all can agree, I cant live without my ax for that long. The switch is completly different and I have no idea where to begin to finish this project/repair.
I know this is a JEM/Universe exclusive (for the most part) site, But I have seen how helpful everyone has been to us "outsiders" so I thought I would give it a shot. I have been to all the manf. and I have gotten no response.
PLEASE HELP!!!!!!!
Despeartly waiting,
John-Ibanez FOREVER!!
rhinojohn2112 is offline
post #2 of 13 (permalink) Old 02-21-2007, 03:35 PM
Reviews: 120
Re: I need SERIOUS HELP!!!! Please?!
Why would using the Fender one be a problem? Anyway, just go get yourself a DiMarzio 5 way switch and you should be fine. You wont be able to use all 5 positions though until you get a single coil but I'm sure you are aware of that.
I've got a 5 way switch still in my RG470 with just an EMG 81-85 combo and until I get a single coil EMG it's wired up so the last position is a kill switch. Unfortunately I couldn't find a wiring diagram either for the 81-85 with a 5 way switch and my Father worked out a wiring plan. Unfortunately I don't have it otherwise I would scan it and upload it here for you.
LonePhantom is offline
post #3 of 13 (permalink) Old 02-21-2007, 06:25 PM Thread Starter
Do I really need to get another switch? nothing wrong with the fender as far as I know, I 'm just not a real big fan of the brand is all. But at any rate, You so SUCK! haha just messin. Dude, you should have saved that, didnt you know I was going to need it?
Thanks anyways. I you come accross anything, please let me know.
thaanks
post #4 of 13 (permalink) Old 02-21-2007, 07:17 PM
Ayrton's Avatar
Why not just get the wiring diagram from EMG?
http://www.emginc.com/support.asp
Ayrton is offline
post #5 of 13 (permalink) Old 02-21-2007, 08:03 PM Thread Starter
Dude, totally tried that, and all the downloads they have on the site are for EMG pup's so I emailed support, and got this message (I thought it was kinda rude, but I could be wrong):
The only Tech at EMG replies:
Here's a diagram. It shows an active pup in the middle, so get the SA.
Best Regards,
Rick Hunt
In-House Technician
EMG Pickups, Inc.
www.emgpickups.com
post #6 of 13 (permalink) Old 02-21-2007, 11:47 PM
Ayrton's Avatar
Wait, you want to actually wire up the OEM single coil? I don't see the point, either lose it or install the EMG SA.
Ayrton is offline
post #7 of 13 (permalink) Old 02-21-2007, 11:53 PM
elcid's Avatar
The fender switch will work fine, but it really doesnt work to mix a passive pickup with actives.
elcid is offline
post #8 of 13 (permalink) Old 02-22-2007, 01:22 AM Thread Starter
Let me ask ya something. Is it possible to modify A 5 way switch, temp, orotherwise?
( I m afraid I know the answer, but I have thought of just about everything else, cant leave anything out.)
post #9 of 13 (permalink) Old 02-22-2007, 01:33 AM
Ayrton's Avatar
I suppose you could, but they are cheap and easy to replace. If I have a pot or switch that gets "funky" on me, I just replace it.
Ayrton is offline
post #10 of 13 (permalink) Old 02-22-2007, 03:42 PM Thread Starter
only reason I am wiring up the OEM is because the manf. States that if you use a 5-way switch with the ZW series, the blank posts will creat feedbadback and possible could blow the speakers in the amp when switch passes over.
So it is causing a bit of a dilema.
post #11 of 13 (permalink) Old 02-22-2007, 06:05 PM
Dude you can not wire the stock single up with the 2 emg's.. so disconnect it... leave it in place for looks and run the EMG's with a 3 way. Or try to figure out how to wire it with the 5 way...
mikeymike is offline
post #12 of 13 (permalink) Old 02-22-2007, 09:01 PM
Reviews: 120
Why don't you just buy a 3 way for the time being and when you get a single coil EMG put the 5 way in again?
post #13 of 13 (permalink) Old 02-22-2007, 09:33 PM
also did you get the right pots for the EMG's?
ibanez guitars , wiring diagram
ok now, need some serious input Eddie_UV777 All Other Guitars (including Prestige) 51 12-01-2006 02:34 PM
WTB:Jem 77GMC serious ziggymartian Classified Ads: Ibanez JEM/UV Guitars 1 05-10-2006 08:39 PM
Atlanta, GA experienced guitarist seeking serious musicians EnigmaUV7 Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 0 10-09-2004 05:02 PM
NY 7 string guitarist/vocalist seeking serious musicians! StarChild Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 0 07-07-2004 03:58 PM
Taking a serious brake... Jay Satriani Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 15 12-30-2001 07:56 AM
