I need tremolo advice!! - Jemsite
post #1 of 7 (permalink) Old 04-18-2010, 12:17 AM Thread Starter
Ok, Here's my problem. I opened up the back cavity of my guitar. I noticed one side of the tremolo "Block" seemed to be "Scraping" against the sides of the cavity. As seen in this picture...
So then i examined the top of the floyd rose to see if it was off set... It was "Straight" but not flush... And was higher on the left side and flush on the other...(As you can see in the pic's.)
Now my action is ok, But what do i need to do. I'm pretty sure the tremolo shouldn't be scraping my guitar cavity... So how do i adjust it, then fix the altered action and return to pitch????? Thanks, for any help given it is GREATLY appreciated..
Last edited by PrestonStrings; 04-18-2010 at 12:28 AM. Reason: I needed to add some notes.
PrestonStrings is offline
post #2 of 7 (permalink) Old 04-18-2010, 12:39 AM
CosmicDebris's Avatar
Re: I need tremolo advice!!
It is obvious not the right trem for that body. Get the right trem or a dremel tool.
CosmicDebris is online
post #3 of 7 (permalink) Old 04-18-2010, 12:41 AM Thread Starter
It's the stock tremolo. Lo trs for the Ibanez 7420.. You can see the tilt of the bridge in the second pic..
post #4 of 7 (permalink) Old 04-18-2010, 01:27 AM
Reviews: 3
don't believe that is the right tremelo...cavity looks like it was already "modified', or as I see, hacked up...also, why the extreme difference in the height from low to high ???
mtldad is offline
post #5 of 7 (permalink) Old 04-18-2010, 01:31 AM Thread Starter
It's the right tremolo, if the block was changed or not idk, well i bought it two days ago used from a music shop, it's a great playing guitar already, I just really can't stand for the things un-perfect. well at least if it's something fixable. By my eye judgments i should be able to just level the bridge and the scraping will cease... Now i guess my question is can i do this? how do i do this? and how will i set my action back up...
post #6 of 7 (permalink) Old 04-18-2010, 07:42 AM
That angle on the bridge is because action is low on the treble side than it is on the bass side. Its normal for it to be slightly tilted.
Yours is TOO tilted but as its a 7 string its understandable that someone using a too thin low B string and trying to get rid of buzz might have raised it that far. Regardless, making the bridge 'level' will compromise the playability of your guitar.
Secondly, the cavity on that guitar has already been hacked up to make that tremolo fit. Its obviously not original hardware.
firstly - Route out the cavity so the trem block has COMPLETELY unimpeded movement along the WHOLE of its travel. That will solve your sticking issues.
Secondly, get the guitars action and string guage sorted out properly. Take it to a tech or do it yourself its your choice, but one side of your bridge is way out of whack.
GuitarBizarre is offline
post #7 of 7 (permalink) Old 04-18-2010, 11:54 AM Thread Starter
Thank you sir, that's just what i was looking for. Thanks everyone!
ibanez seven string , tremolo lo trs
PRS tremolo vs. Floyd Rose pro tremolo bjamin86 Tech: Setup, Repairs and Mods 5 01-25-2010 09:27 AM
Any advice on putting Tremolo from a JS1000 into a custom body? Stevodod Ibanez JEM, UV, JS & Other Signature Models 2 08-02-2008 01:18 PM
New tremolo Kramerman Tech: Setup, Repairs and Mods 2 02-09-2008 09:57 PM
Zr Tremolo superhairycamel Comments to Ibanez 16 01-04-2006 05:59 AM
