I think I need a new edge... - Jemsite
post #1 of 13 (permalink) Old 10-14-2008, 11:37 PM Thread Starter
Unhappy I think I need a new edge...
Hi guys. I just got my first Ibanez (RG520) a couple of days ago and it played fine until today. Basically I was messing around with the edge for a bit and when I pulled it up the springs "snapped" on me and the bridge came off the studs and the blocks inside the saddles came loose; all of it.
So I'm guessing this is pretty much unrepairable and I might as well just go **** shopping for another edge?
huyn3938 is offline
post #2 of 13 (permalink) Old 10-14-2008, 11:44 PM
Reviews: 21
Re: I think I need a new edge...
The springs "snapped"?!? I don't understand exactly what happened. Do you have pics?
mike570 is offline
post #3 of 13 (permalink) Old 10-14-2008, 11:46 PM
that is horrible simply horrible, are you a body builder or something. jesus post pics please.
mrjakob69 is offline
post #4 of 13 (permalink) Old 10-15-2008, 01:22 AM
Tremolos are the devil.
callen3615 is offline
post #5 of 13 (permalink) Old 10-15-2008, 02:10 AM
Ayrton's Avatar
Post some pics and I am sure we can help.
Ayrton is offline
post #6 of 13 (permalink) Old 10-15-2008, 05:03 AM Thread Starter
I don't have a camera except for my phone which I lost the cable to connect to my laptop anyway. Hopefully you guys can get the picture with the details (sorry about the no pics)
I guess "snapped" isn't the right way to say it since I didn't actually snapped the springs off (though I probably did overpower it on the pullup), but that's how the bridge came loose from the studs and now it squeaks like crazy whenever I try to divebomb with it, and the bridge itself is harder to set up parallel to the body now. With the strings off, the bridge came off the studs (I don't know if this is uncommon or not, but this guitar is also my first experience with a floyd rose) even if I put a little block there to stop it from sinking into the cavity. Surprising, I can still use the saddles even if the blocks are loose, but I can't keep the low E string in its saddle as the block won't hold it in place.
huyn3938 is offline
post #7 of 13 (permalink) Old 10-15-2008, 06:30 AM
Reviews: 21
Forgive me if this sounds bad, but I'm just trying to figure out what happened.
Did your individual saddles slide free from the intonation screws? Open up the back. Did one of the springs pop off the big block on the bottom of the trem? Did the trem simply slip up off the studs? I've had that happen on a rare occassion though it's a bit more common with Edge 3, especially after changing strings.
mike570 is offline
post #8 of 13 (permalink) Old 10-15-2008, 12:02 PM
I can't figure out what could have happened though it sounds fixable. The bridge is not supposed "ttached"to the studs. Merely anchored against. Maybe it's lined up wrong now. If it is, you are probably killing the knife edges (hence the squeak).
If it will help you out, you can take a pick w/ your phone and send it to my phone, I will post it on here for you. PM me for the #.
Bowie is offline
post #9 of 13 (permalink) Old 10-15-2008, 01:01 PM
jb4674's Avatar
Reviews: 18
All jokes aside, you should take a look at Rich's setup page and try to figure out what's going on and why the string blocks came loose.
Jimmy
jb4674 is offline
post #10 of 13 (permalink) Old 10-15-2008, 04:20 PM Thread Starter
^ I think you're actually right and I will take a look at that page. I finally figure one part of the problems: I didn't adjust the spring tension to my strings (.12-.56) let alone add another one lol... The spring still sqeak a bit but the guitar now stop sliding off the studs once I put .9-.42s on there.
Don't know what to do about the loose blocks though. I put them back into the saddles and luckily they hold the strings in place except the for the .42 which been sliding off for several tries. Tunings have been... Urgh.
Thanks for the help guys. I appreciate it.
huyn3938 is offline
post #11 of 13 (permalink) Old 10-15-2008, 07:54 PM
It sounds like the springs just came loose from the block, in which case the trem would get pulled right off the studs by the tensioned strings. Either way, it should be easy enough to put back together. Put a spring retainer bar on it this time.
ryanb is offline
post #12 of 13 (permalink) Old 10-15-2008, 08:06 PM
jb4674's Avatar
Reviews: 18
I also think that the fact that you're using 12's in that axe isn't helping matters very much.
Jimmy
jb4674 is offline
post #13 of 13 (permalink) Old 10-19-2008, 09:47 PM
Take the picture, then send a picture message to your email account (instead of a phone number, just put the email address). Voila!
Act of God is offline
Edge posts w/ set screw. Will they fit in an Edge III hole? Stygian Tech: Setup, Repairs and Mods 1 06-23-2008 05:57 PM
Replace Edge Pro With Edge/ Lo-pro Edge Trem Vaistarr Tech: Setup, Repairs and Mods 28 04-01-2008 12:18 PM
Edge/Lo-Pro Edge/Edge Pro Arm (x2) damo7v Classified Ads: Guitars and Gear 0 11-25-2006 02:16 PM
Lo pro edge & Double Edge in tune problem Raffel Tech: Setup, Repairs and Mods 21 05-14-2004 08:59 AM
My beef with Ibanez's Edge & Lo-Pro Edge tremolos. cyberman Comments to Ibanez 2 01-06-2003 11:46 PM
