Ibanez 450, Weird Original Edge - Jemsite
post #1 of 4 (permalink) Old 11-05-2013, 10:27 AM Thread Starter
Gents,
what is your take on the 450 made in japan (the ones with original edge)?
as far as I can tell, the only difference is the beefier neck joint (which has a fat heel, not slanted like 550/jems). I'm considering buying one and would like to get your opinion on them.
Also, is this bridge legit or what? This "step" looks weird to me
mag8 is offline
post #2 of 4 (permalink) Old 11-05-2013, 11:52 AM
Re: Ibanez 450, Weird Original Edge
The "step" in the bridge means it's broken ... The broken piece (which is the edge of the vibrato) does not withstand much strain, this is why it doesn't fall off, the knife is supporting it and withstands at the same time the tension of the strings.
asdsorin is offline
post #3 of 4 (permalink) Old 11-05-2013, 12:04 PM
RGTFanatic's Avatar
That's a correct 450...... probably a '91 model. The knife edge on the trem looks to be intact and in the correct position. It may be a little fugly looking, but my guess is that it will function perfectly.
You are correct that the heel and input jack are the only differences between this and a 550
FWIW..... the "step" looks like it was ground down on purpose. I'd ask the seller for any information on why- if the info is even available.
RGTFanatic is offline
post #4 of 4 (permalink) Old 11-05-2013, 04:35 PM
Yes, the little 'tab' is broken off, but the knife edge is still seated correctly.
Seen a few instances of that, but on the bass side (one of my guitars came this way). Doesn't affect trem performance, in my experience.
Ashurbanipal is offline
original edge , rg 450
original edge or lo-pro edge on ibanez rg350 saeed-satriani Tech: Setup, Repairs and Mods 4 12-11-2009 01:56 PM
Does Ibanez still make the Original Edge? mike570 All Other Guitars (including Prestige) 15 05-05-2008 11:47 AM
FS: NEW IBANEZ Edge Adjust (original first Run) LuredMaul Classified Ads: Guitars and Gear 4 08-16-2007 01:33 PM
Original Ibanez Edge 4 Sale heem6 Classified Ads: Guitars and Gear 1 01-13-2006 09:07 AM
Wtb:WTT for ibanez original edge, have lo-pro j.arledge Classified Ads: Guitars and Gear 3 12-19-2005 08:57 PM
